Old 03-05-2020   #11
Flyman 27
Flyman 27's Avatar
Default Re: List of things to do while 90 is torn down..sugestions
With the dash off, it would be a good time to install a shift light hidden in the A/C vent.
Heater cores are not an uncommon failure point on C4's. If you can find a good one or have a shop rebuild yours? Do they do that anymore?
While the rear gear is empty of oil, it would be a good time to add a drain plug for next time. Mark H. has info on that.
Cams by Pete
