#11 | |
#12 |
![]() Join Date: Sep 2008
When you read the FSM, it states that a "No Crank Condition" can occur if the Vats protocol does not complete.
While they do not specifically state anything about fuel pump activation, I am under the impression that fuel pumps turn on as do other systems such as vacuum pump regardless of VATS, as I have witnessed fuel pumps etc. turn on even though the car would not crank. You likely will not get pulse if VATs was unsuccessful as well. These were empirical observations on actual no starts, so do not take it to the bank, except for the first line which is from the FSM and empirical. Marty |
#13 | |
