11-25-2019 | #1 |
93 Starter Not Engaging
Went to start car after a few months of storage. Battery was low so I charged it overnight. Turns out it would not take a charge, 6 yrs old, so I bought a 700 cca battery and installed it. All dash lights come on, can hear fuel pumps but when turned to start I get nothing, no solenoid clicking, nothing. In searching the forum seems like this is a problem. Car has only 10,000 miles and always started, although it does sit in a dry warehouse most of its life. Can it be security? The passive lock unlock is not working although it always did. Shoul I try battery in the remote? Even manually hitting lock or unlock on the remote does nothing.
11-26-2019 | #2 |
Re: 93 Starter Not Engaging
Depress Clutch all the way
If the solenoid does not move (no clicking indicating the Starter Solenoid moved) then a sticky Solenoid or Solenoid Ground Connection. Or.....you do not have 12 volts in purple wire. You can hot wire the starter (purple wire) when that happens to see if it is the starter or starter ground circuit. Or check that purple wire for 12 volts when you turn the key to start. If you have 12 volts in purple wire (key turned to start) it be the Solenoid is stuck or connection of purple wire to solenoid is bad. You really need someone in seat turning the key to start with Clutch depressed. Post 52 - Starter, Starter Relay, Wiring Harness, Battery, and Plugs Tricks
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-29-2019 at 08:21 PM. |
11-26-2019 | #3 |
Thank you, I will try. Where is purple wire?
11-26-2019 | #4 |
The firewall on the drivers side inside the large wire loom, between the ecm and the engine. its either 10 or 12 ga wire
11-26-2019 | #5 |
Great. I'll take a look and give it a try. Thank you.
11-26-2019 | #6 |
Took a look and there are 2 looms. I was able to open the larger and did not see any purple wires that were even close to 10 or 12 gauge. I also did not see any voltage drop while depressing clutch or attempting to start. Any one have a picture of where this wire is?
11-26-2019 | #7 |
The purple wire is red on the first three hundred or so ’90 cars. But as far as I know should be Purple after that. If a heavy red wire....maybe.....
Post 53 - Electrical Ground Connections and Installing Starter Relay |
11-26-2019 | #8 |
Remove your Drivers side Floor Mat and try it again.
Marty |
11-26-2019 | #9 |
Ok, I'll try removing the mat. Actually did not see any color wires that were any bigger than maybe 16 gauge.
Maybe I should jump out the clutch switch. Can it be seen without removing the lower dash panel? |
11-26-2019 | #10 |
This is an early 90' so wire to Solenoid is red 12 gage. The photo shows part of installation of Starter Solenoid Relay. Post 53 - Electrical Ground Connections and Installing Starter Relay Maybe 93' has differences
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-26-2019 at 10:06 PM. |
