Old 10-24-2019   #1
albeR/To
Default '94 ZR-1 Engine/Car Rebuild
Hello Everybody!
After like two years since I bought the car from Kris and less than 10 miles behind the wheel (the car was impounded after few kilometers away from the customs office and after 3 days in italy because of expired temporary license plates and it costed me a "small fortune" to get it back) I decided to begin a big overhaul of the car.
I started immediately by fixing some small issues around the car, but everytime I removed something I found something worse behind it...
At the end a couple of month ago I decided to remove the engine and start from everything from scratch.
In this thread I will share my experience/story of the rebuild of the car and I hope to find some help from you guys.
When I got stopped by the police...
When it arrived at home
At the workshop with one of its sisters
The engine just before the removal
Almost ready to be removed
The engine is on the ground!
Lets the nightmare begin
First surprise: camshaft lobe tips are ruined (seems like pitting)
On both banks
Crankshaft doesn't look bad
albeR/To is offline   Reply With Quote
Old 10-24-2019   #2
albeR/To
Default Re: '94 ZR-1 Engine/Car Rebuild
Now I'm already stuck...can you suggest me the way to remove the spacer on the crankshafts between the chains sprocket and the oil pump?
Old 10-24-2019   #3
grahambehan
If you have the sprocket removed, the spacer is a slip fit and should be able to be rotated and pulled forward off the crank.
Graham
grahambehan is offline   Reply With Quote
Old 10-24-2019   #4
jss06c6
Wish I could see your pictures, but unfortunately cannot. Keep at it, it's worth the effort.[emoji41]
Steve
Old 10-25-2019   #5
albeR/To
Graham
I removed the sprocket, but the spacer doesn't seem it wants to move...the spline also seems stuck...on monday I will try again.
Steve
I will use a different pictures host (I used Microsoft onecloud, but it doesn't seem to work)
Old 10-28-2019   #6
albeR/To
Main bearings completely gone
Pistons are ok, just a lot of dirt on them
Old 10-28-2019   #7
G8nightman
G8nightman's Avatar
You need to resize those pictures
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 10-28-2019   #8
Alberto,
Sono stato a Salo e Sirmione molti anni fa con famiglia. Bellissimo.
Old 10-28-2019   #9
BigJohn
BigJohn's Avatar
Molto cool Italiano
Old 10-28-2019   #10
S.hafsmo
S.hafsmo's Avatar
What caused you to remove the engine in the first place? I seem to have missed the background story. What could have wreaked havoc in the entire engine?
- '90 ZR-1
