![]() Join Date: Dec 2003
NEW Dowty Washers: Better sealing because (1) it also seals around the bolt, whether stock or aftermarket with full size shank, (2) wider seal, (3)it is self centering and won't leave the thin seal in the gap between the bolt & cam cover hole and (4) less expensive.
Sold in complete set of 48 pkg only = $49.75 pkg will contain 50 dowty washers in case you drop & lose a couple... http://jerrysgaskets.com/store2/root...products_id=30 Shipped U.S. Priority Mail. No extra charge for additional packages if you want more than 1 set. Contact me for shipping quote if you require international shipping. Here is a photo so you can see the difference between the new one and the OEM dowty washer. ![]()
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 10-01-2011 at 10:29 AM. |
These look great!
![]() Makes one wonder why they weren't done that way in the first place. ![]() Refresh my memory - Where does the "Full Size Shank" bolt go? ![]() |
#3 | |
Jerry,
Thanks - - - I was all confused, was afraid that I didn't have the correct OEM cam cover bolts. ![]() |
#5 | |
![]() Join Date: Jul 2004
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
#6 | |
