08-12-2019 | #1 |
C8 Corvette
According to the WSJ, GM will not be producing hybrids in the future. So we can assume the C8 will remain a gasoline vehicle for this generation, SANs the stick shift.
https://jalopnik.com/there-is-no-hyb...1837166788/amp Sent from my iPhone using ZR-1 Net Registry
08-12-2019 | #2 |
Re: C8 Corvette
I'm not sure that I'd believe that story to apply to the C8.
One reason GM went to a mid-engine car is the platform was "maxed out" at 755-hp much less for an even more power. The only way to make the car perform well with more horsepower is all-wheel drive. If the Corvette was to be "all-IC" GM will have to develop a complex and heavy mechanical system to transfer torque from the mid-engine to the front axle. Another way to get AWD and dispense with a prop shaft and a drive axle assembly is to use electric drive up front. This system would not be capable of moving car by itself. It would be enabled only when the driver wants maximum torque output. The battery pack would be pretty small. There are other high-performance sports car which use a hybrid configuration in this manner. I'm going to guess a V8 with 550-600-hp driving the rear wheels and 300-400 hp worth of electric motor(s) driving the front wheels.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 11-24-2019 at 02:33 PM. |
08-12-2019 | #3 |
Re: C8 Corvette
Hib,
I would tend to agree w u. The use of electric drive would also have the advantage of literally dynamic torque vectoring.
08-12-2019 | #4 |
Re: C8 Corvette
I don’t think any executive at GM would go against Mary Barra’s future vision for GM of only full electric powered vehicles. You’ll just have to wait for the C9, if you’re young enough.
11-07-2019 | #5 |
Re: C8 Corvette
Here are the official C8 performance numbers
Official Performance Numbers Louis, what happens when you set out to improve upon the storied legacy of Chevrolet small block engines? You get the all-new 6.2L LT2 V8 on the 2020 Corvette Stingray. This powerhouse helps Stingray achieve its official performance numbers, including a top speed on a race track of up to 194 mph. Plus, with the available Z51 Performance Package, it can take you from 0–60 mph in just 2.9 seconds1 and boasts a time of 11.2 seconds @ 121 mph1 in the quarter-mile. Sent from my iPhone using ZR-1 Net Registry
11-07-2019 | #6 | |
Re: C8 Corvette
11-07-2019 | #7 |
Re: C8 Corvette
Bob,
Then you should wait until 2022... https://www.automobilemag.com/news/2...id-engine/amp/ Sent from my iPhone using ZR-1 Net Registry
11-08-2019 | #8 | |
Re: C8 Corvette
11-08-2019 | #9 |
Re: C8 Corvette
You forgot the 5th “B” - Babes. I’m just a few years behind you. I might go for a used Z51. I can will my Z to my son and a black (daughter loves black) Z51 to my daughter. That if I live a little longer.
11-09-2019 | #10 |
Re: C8 Corvette
With all the bitching about the dual clutch, I had to look it up!
https://www.youtube.com/watch?v=HLOwY3w_TNc |
