Old 07-26-2019   #11
Karl
Karl's Avatar
Default Re: Cam Sensor Questions
I am at work and can't find the post but there is a vendor that sells the sensors as I have one
It needs to be modified for it to work as noted in prior post.
I can find the vendor later.
1985 L98 Blue On Blue *Sold*
Old 07-26-2019   #12
Karl
Karl's Avatar
If you look around these links you will find the vendor if not I can look later.
http://www.zr1.net/forum/showthread.php?t=30588
Old 07-26-2019   #13
Karl
Karl's Avatar
The sensor.
https://www.diyautotune.com/product/...sition-sensor/
Pages 3 through 6 are useful.
http://www.zr1.net/forum/showthread.php?t=28584
I have a spare just for the heck of it.
Old 07-27-2019   #14
Jetjock
Jetjock's Avatar
Did you do this with a 90 or a 91 for testing? It took all day to take the old sensor out and another day to get it in. The ASR is right in the way and I have large hands. It is done.
Roy L. Carman
If I feel the need for speed,
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Old 07-27-2019   #15
32valvZ
32valvZ's Avatar
Wow, that ASR must be a huge PIA.... I was done on my 90 in about 15 minutes, remove and replaced... Did it from under the car.
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 07-28-2019   #16
Jetjock
Jetjock's Avatar
Yes, it was a huge pain. I have a pint of oil on my garage floor from swapping out the sensor. The ASR has a lot of hoses under it that was constantly in the way. Don’t want to do that again anytime soon.
Roy L. Carman
NCM Lifetime #1468
Old 07-30-2019   #17
Jetjock
Jetjock's Avatar
Well, replaced the cam sensor and worked on my FX3 right rear timeout. Started up the car and it would barely run. WTF! Shut it down and pulled the code 31. So now I’m going to have to check around the ASR to see if it got put back correctly and check the connection on the cam sensor. It sounded like I only had 4 cylinders.
Roy L. Carman
NCM Lifetime #1468
Old 07-31-2019   #18
Jetjock
Jetjock's Avatar
Phil’s inbox is full so I’m posting here. Got the sensor out and added a washer to it to increase the air gap on the sensor. Didn’t work. Ran a little better but still messed up. Tomorrow, I’m going to add another washer to try to increase the air gap a little more. The good news is that I can take apart the ASR and A.I.R. stuff in about 5 minutes. Had no idea that this could happen.
Roy L. Carman
NCM Lifetime #1468
