Old 07-05-2019   #1
jpalmer1717
Default Can't get into gear...
I've been noticing that getting into gear from a stop has been difficult. It got worse quickly. Now I can't hardly get the shifter into gear and also noticing the clutch is catching almost instantly when letting it out. What is happening??
jpalmer1717 is offline   Reply With Quote
Old 07-05-2019   #2
SAHall
Default Re: Can't get into gear...
I had a similar issue and it turned out that my clutch fluid was very low. I filled the reservoir and it was like I installed a new clutch. Good luck.
SAHall is offline   Reply With Quote
Old 07-05-2019   #3
Also check the fork/Pivot ball .....
Old 07-05-2019   #4
jpalmer1717
Dumb question- where is the reservoir located?
Old 07-05-2019   #5
32valvZ
32valvZ's Avatar
under the computer on the driver side firewall
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 07-05-2019   #6
SAHall
Yes, it’s on the driver’s side, close to the firewall and under the computer.
Old 07-06-2019   #7
jpalmer1717
Well, that definitely would appear to be the problem as the well looks empty...but for the life of me I cannot get the cap off.
Old 07-06-2019   #8
If...when you do remove the cap, you or your mechanic should bleed the clutch MASTER and SLAVE cylinders first. Then keep a close eye on the level, looking for signs of leakage.
Good luck!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 07-06-2019   #9
lfalzarano
Channel lock pliers for the 1st time is needed.
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR]
Old 07-06-2019   #10
I also had to use Channel lock pliers the first time, just wrap the cap with a rag. When refilling keep the level below the full mark or when you insert the black cup it will overflow.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
