![]() Join Date: Jan 2018
Hello all
Could someone please help me understand if my cooling system is working as it should. More specifically if the termostat in the refill lid is working and the expansion tank doing its thing. The reson why is that no matter if the car is warm or cold the level in the expansion tank seems to remain at cold. The temperature of the coolant there also seems to be cold. Also, sometimes I have needed to add a small amount of coolant in the main reservoir to top it of up to the exanpsion system hole. I tested and blew air into the expansion hole and it bubbled in the expansion tank so there is no restriction there. Is there something I am not understanding here or do I have an issue? The thing that bothers me most is that I may need to top of the reservoir eventhough the level in the expansion tank is good... Also, there are no leaks that I have seen so far. Thanks in advance guys! Sent from my EVR-L29 using ZR-1 Net Registry mobile app |
Radiator Cap on Reservoir in front of passenger firewall might be leaking and not holding 15 lbs pressure. During cool down Air is entering through the Radiator Cap as the Cooling System Retracts.
Time for New Radiator Cap ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-04-2019 at 09:15 AM. |
#3 | |
![]() Join Date: Dec 2003
#4 | |
#5 | |
Jerrys Gaskets does not have any in stock, but here is what it is supposed to look like. ![]()
![]() Join Date: Aug 2006
My 94, even with working radiator cap, coolant level in the overflow tank typically settles at cold marking. As long as coolant stays even and not disappear on you, I wouldn't worry.
Also, if you are running silicone hoses, check and tighten all clamps. I was loosing coolant and turned out clamps were loose. Situation like this, seepage would occur only when the motor was hot and evaporate as it seeped making it next to impossible to notice. |
#7 | |
#8 | |
![]() Join Date: Nov 2007
If the leak is external, then you should be able to smell the coolant as it evaporates. I had the same issue and it was a loose clamp on a silicone hose. When completely cold, sometimes Id see a small spot on the garage floor... not always, but sometimes. Drove me crazy. One day, while cleaning under the car, I was able to spot a glint of coolant sitting where the hose slipped over the T Stat housing. Took maybe a 1/4 turn and the leak hasn't returned.
You can pressure test the cap as well as the system with a cooling system pressure tester. Pretty inexpensive tool really... nice to have though. |
#10 | |
