Old 06-08-2019   #1
Regimof3
Default Loose front caliper?
Noticed a noise up front recently and decided to have a local shop look at it as well as give it a brake system flush. He says I have a "loose fitting caliper". Says the bracket and hardware need replacing. I'm sure the topic has been discussed ad naseum, (I did do a search and there have clearly been many options), but I'm just curious if anyone knows what options are still out there today. Lord knows finding parts isn't getting easier.
Should I just get an oem replacement? Are they available? Would I be better off buying a different set for the front that could be an improvement?
I get worried when I have to buy parts as almost Everytime I do, it involves some kind of complication.
Still worth it tho
Regimof3 is offline   Reply With Quote
Old 06-08-2019   #2
Default Re: Loose front caliper?
The brakes are the same as the base car from 95-96 I believe. What you want if a J55 caliper and bracket if you even need to replace it,these calipers -float- somewhat.
Old 06-08-2019   #3
What bracket? The caliper bolts to the spindle directly. If I was going to look to replace, I would use the C5 front calipers.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-08-2019   #4
WVZR-1
This is 'wrong' - caliper is retained with pin & e-clip in the abutment.
OP - ask shop to show you! It's certainly possible
This is a very 'generic' '88+ caliper image. e-clip placement is sometimes debated whether inboard or outboard but FSM shows 'outboard'.
Old 06-08-2019   #5
Ronstar
I have a lightly used set of grand sport calipers I would part with.
Ron Thompson
1990 421ci ZR-1
2010 ZR1 (stock)
Ronstar is offline   Reply With Quote
Old 06-08-2019   #6
conesare2seconds
If you hear a rattle over bumps it could be as simple as a broken anti-rattle spring on a pad. Worth inspecting the pads.
Old 06-09-2019   #7
Ccmano
Ccmano's Avatar
C4 or C6 Grand Sport Calipers?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
