Old 06-02-2019   #31
Locobob
Default Re: Pulley Failure
Robert
Old 06-02-2019   #32
Locobob
Robert
Old 06-02-2019   #33
Locobob
Robert
Old 06-02-2019   #34
Locobob
Robert
Old 06-02-2019   #35
Locobob
The pulley turns freely and doesn't make any obnoxious sounds, it does feel a bit sloppy however.
Robert
Old 06-02-2019   #36
HAWAIIZR-1's Avatar
Wow! Thanks for sharing. I did check mine out last week after you posted and it seems okay. I’ll keep an eye on it just in case.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 06-02-2019   #37
BigJohn
BigJohn's Avatar
Air Cooled Pulley?
Old 06-02-2019   #38
I have some wear on the pulley from the back side of the Serpentine Belt (must be from the belt flexing as it "bends" around the aluminum pulley). It appears the wear on Locobob's pulley is much more as it appears the back side of the Serpentine Belt has worn completely through the Aluminum surface as I can see ridges (Serpentine Belt is a bit narrower than the pulley riding surface between the two guides).
I am replacing ALL Billet Aluminum Belt Tensioner Pulleys with New Stock Belt Tensioner Pulleys immediately. Why wait
I am not sure why this pulley wears as it does and the vender says he has seen no issues with this pulley. I can confirm the Backside of the Serpentine Belt does wear on the Aluminum in this application.
How many miles on this failed Belt Tensioner Aluminum Pulley?
Old 06-03-2019   #39
Locobob
The pulley probably had less than 15k miles on it. I mentioned it to Haibeck and he said he's seen two other failures of the aluminum pulley just like this one. So if you have this pulley you better keep a good eye on it. I have the pulley removed from the tensioner now, still no idea why it failed. It seems to spin about the same as the old Dayco pulley I have laying around - both on the shaft and on my finger, no obvious signs of bearing failure. By the way this "lightweight" aluminum pulley is actually 1oz heavier than the Dayco so there's really no reason to run it other than looks.
Robert
Old 06-03-2019   #40
HAWAIIZR-1's Avatar
Default Pulley Failure
Locobob and Dynomite,
Noted!! I did see my pulley had some wear and I should be concerned too. I don’t have much mileage on mine and probably why minimal wear. I also understand that bearings can behave differently free-spinning with and without load on them.
It seemed like a good idea and nice mod at the time. Maybe just a bad pulley or bearing, but well noted to observe or replace with stock type. I’ll check mine with more detail when I return home. Thanks again for sharing your thoughts and experience.
I guess the moral of the story is to leave sh#t alone!!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
