Old 06-01-2019   #1
Subfixer
Subfixer's Avatar
Default AC conversion
Since my AC system is empty of R12, I'm going to convert to R134a.
I've got a new compressor on order, but I need the rest of the required parts.
Is there a list, or kit, somewhere that has everything else I'll need?
Thanks, Paul
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers
2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige
Subfixer is offline   Reply With Quote
Old 06-01-2019   #2
fred
fred's Avatar
Default Re: AC conversion
You probably don't need a compressor, unless that s a known problem or the cause of your leak...most likely culprits are Schrader valve or bad hose. Any parts store has a good conversion kit (oil and connections). Expect about a 15% loss in cooling, but it still works great in Phoenix …. for about 20 years, so.....
fred is offline   Reply With Quote
Old 06-01-2019   #3
Ccmano
Ccmano's Avatar
That’s a matter of much debate. Years ago we simply got the R134 oriface tube and fresh PAG oil. Evacuated, then just charged it with R134. Worked fine, never had an is issue. Today they want you to change everything. At minimum I would change out the receiver dryer simply because of age. I’m sure you will hear other opinions.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 06-01-2019   #4
Subfixer
Subfixer's Avatar
I read some articles in some past HOB issues detailing the change.
Looks like I have some work ahead of me.
Pulling the plenum anyway due to a fuel leak.
Old 06-02-2019   #5
Subfixer
Subfixer's Avatar
Did the 93-95 ZR-1 go to R134a when new?
If so, was there a different condenser?
Thanks
Old 06-02-2019   #6
Yes not sure on 93 but 94-95 were R134a.. different pieces in the system and the condenser was a parallel flow not the tube and fin used with R12
Old 06-02-2019   #7
Subfixer
Subfixer's Avatar
ok thanks. Since I need a new condenser, I'll get one for a 94-95 plus all the other stuff I need.
Old 06-02-2019   #8
You will need everything to my knowledge as the fitting are different and I think the oil cooler may have to change to mount correctly to the new condenser
Old 06-02-2019   #9
Subfixer
Subfixer's Avatar
Hahaha.... if it's not one thing, it's another.... the joys of owning an old car.
Old 06-02-2019   #10
32valvZ
32valvZ's Avatar
1994 was the first year for all US automobiles to be mandated to have R-134a
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
