Old 05-30-2019   #1
Vette73
Default Service ride control light..
Rear shocks have been leaking for awhile..Picked up a good used set from a member awhile back..
Car was in for CV joints the last few days so I told my mechanic to swap out the rear shocks for me....
Service ride control light is on now...
What's the steps to eliminate this?
Shocks I put in seemed to be in working order...
Old 05-30-2019   #2
dredgeguy
dredgeguy's Avatar
Default Re: Service ride control light..
Same happened to me when I put in new shocks. My Wazoo brothers told me don't worry about it and just drive. The system has to relearn and when it is done the light will go off. They were correct. Can't remember how long it took but it will go off.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 05-30-2019   #3
Vette73
Ok Charlie Thnx for the info.....
Old 05-30-2019   #4
G8nightman
G8nightman's Avatar
That’s the case if the key was switched on and off 3 times without the car rolling I’m not aware of any learning after the shocks are installed I know the system will run a test and if something is out of wack the light will go on and stay on. Best thing to do is check the codes and see what it is complaining about.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 05-30-2019   #5
Correct!
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 05-30-2019   #6
Jetjock
Jetjock's Avatar
I currently have the same problem after I installed new shocks back I bought the car in 2009. It went out but It came back on in the last few weeks. I asked Gordon about it and he said tighten down the nut as they will work loose. I haven’t done it yet but I will next week.
Roy L. Carman
If I feel the need for speed,
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Old 05-31-2019   #7
Based on my experience, when I installed a brand new set, it took a while for selective ride system to function properly and turn off the the warning linght. I think this was due to new shocks having a bit of resistance in turning the gear on top which loosened up after a while.
When gear is turning freely (as in used shock), as mentioned below, for fronts, I would check gear to planetary gear in actuator relationship. Look for crushed rubber bushing below the cup or cup being too loose.
Old 05-31-2019   #8
billschroeder5842
billschroeder5842's Avatar
Vette73... jump the pins and get your fault codes. It will be pretty straight forward after that. Until you do that, you are just guessing.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 06-04-2019   #9
Hib Halverson
SRC does not have a "learning" capability.
If the service ride control light was on then went off, the problem, whatever it was, went away. The SRC controller is like others on the car in that after a certain amount of cycles with the fault not present, the controller turns the service light off.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 06-05-2019   #10
dredgeguy
dredgeguy's Avatar
Since I was mistaken on the SRC "learning" it now came back to bite me. Now my Service Ride Control light is on!!! Shows a code 21 which is left front time out. I hope it is the small gear on top of the shock as that is a simple fix and did it a few years ago.
Charlie
__________
Dredgeguy
Dana 4:10 gears
