Old 05-23-2019   #1
Locobob
Default Pulley Failure
So a couple of years ago my tensioner went bad and I rebuilt it using a combination of stuff including some L98 parts and this aluminum pulley from UPR products (the pulley specs as a 85-93 Mustang ultra light tension/idler pulley). I remember I followed the tensioner rebuild project of someone on here, so if you have this pulley I suggest you check it. I can't think of any reason other than poor build quality as the cause, there are actually several holes although you can only see the one in the pic. The belt shows some damage too, I was noticing some odd coolant temp and voltage fluctuations which is why I started poking around. Guess I'll go back to the factory pulley.
Robert
Old 05-23-2019   #2
Ccmano
Ccmano's Avatar
Default Re: Pulley Failure
Bearing failure?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 05-23-2019   #3
Locobob
Bearing failure?
H
Possibly... I have been noticing a silvery oily residue under the air horn and around the general vicinity of the belt. Although I think that is from a leak in the A/C system which is another area I need to address and that could also account for belt slippage.
Robert
Old 05-23-2019   #4
LB,
Looks like it wasn’t worth the extra hp.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-23-2019   #5
Ccmano
Ccmano's Avatar
Judging from the hole in the pulley (which is aluminum) looks like it froze and the belt wore a hole in it, might be the source of your silvery residue?
H
Old 05-23-2019   #6
Locobob
H
Hmmm, that's a good possibility
Robert
Old 05-23-2019   #7
H
Yup. Beat me toit!! Pully seizing up.
Bob: I replaced mine with a GM pulley for a C4 LT1. Works no for over 10 years! Also, Jerry's Gaskets has ZR-1 pulleys, IIRC.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 05-23-2019   #8
Jagdpanzer
Jagdpanzer's Avatar
After looking closely at the photo appears it could have started as fatigue crack.
Is the center section of the pulley solid or spoked?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-23-2019   #9
efnfast
Pretty sure Jim Voter had that exact same pulley fail on the way home from BG
Old 05-23-2019   #10
HAWAIIZR-1's Avatar
It’s hard to imagine that billet aluminum is weaker than plastic (stock) and I agree it has to be bearing failure with a seize that heated and burned by the belt friction. It would seem that would be noticeable though. I’m tempted to go back to stock myself. I guess another reminder to make America great again and we need better quality parts overall and stop outsourcing if this is from China.
I can’t remember the Dynomite post. Was it bigger and needed and larger belt too? If same sized belt used it could cause more tension on the pulley than it should have? Thanks for sharing since some of us did this mod.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
