05-20-2019 | #1 |
RH Hip Replacement--Can You Get In and OUT?
Hello All,
This may be under the wrong heading, But : Just got my RH hip replaced 4-29-19. Have averaged 2.2 miles walking per day since. Start PT tomorrow. Have been cleared and have driven a few slow miles in town using our daily Honda Accord and the 2002 VW Cabrio. In about 3 weeks I was going hook up the battery in the Z and go for a drive. I wanted to hear from some of you about how you approached getting in and out with out going out of spec with the hip bending rules. I had the robotic Anterior surgery which explains my quicker recovery. Not sure about getting out from that low seat, even if I can park and get the door wide open!! Thanks for any insights and response, Terry Gonyaw 91Z 1838 Gainesville, VA. |
05-20-2019 | #2 |
Re: RH Hip Replacement--Can You Get In and OUT?
I didn’t have a hip replacement but I did fracture my Femur in a road cycling crash nearly 4 years ago. I continue to ride. The ortho pinned it w 3 titanium bolts. Lifting the thigh and entire leg takes work, but driving the ZR provides the motivation to keep at it. At the beginning its not easy to get in or out. And w a traumatic injury like that, the muscle wants to contract thereby diminishing your flexibility. Important to stretch. A good sports PT is a huge help in rehabbing.
05-20-2019 | #3 |
RH hip , communuted acertabulam with fractured iliac crest. 2011. Femur ok. 6 month recovery to 80 percent
LH hip, ORIF of femur ball 2007 I have changed my style how I get into any car. You can do it. Exercise and stay loose. Hips get sore with narrow seat bolsters. No way can do a 90 seat.
05-21-2019 | #4 |
Had LEFT Hip replaced.
Very little issue dropping down into the car, and getting up to exit. However, when I enter the passenger side of nearly any car, I do have a little bit of an issue pivoting upon entry. Cannot get into the passenger side of a C1 due to the wrap around dash. In summary, you should be fine with your ZR-1. Marty |
05-21-2019 | #5 |
Good to know all this. "Replacing ball joints": I have a scheduled RH hip replacement for June 11th. Wish me luck! (The LH to follow. I'll let y'all know how a DUAL hip replacement goes.)
05-21-2019 | #6 |
Thanks for the responses!
I guess old parts are old parts where ever they are found. Sounds like if I stick with PT-keep flexing and moving, I will be able to get in and out! Will see how narrow the 91 seat feels after I get there. About 5-7 and 180; so that should help. Good luck Paul, Keep moving; the lady at Reston Hosp. here had me walk from the recovery room bed in the hall to my overnight bed at the Hospital. They are big on pain management and just walking using a walker to get your correct gait and posture back! I still must remind myself to stand up straight. Such a strange and good feeling! Thanks again, Terry |
05-21-2019 | #7 |
I drove for Hertz for about 5 years, and they said the correct way to get into any car is to sit down ,then turn and bring one leg in at a time. This was also told to me by PT when i had may total right shoulder replaced.
Hope this helps John 1990 white/black #2546 one of a few auto Eq 4l8OE ZR-1's |
05-21-2019 | #8 | |
Hoping to stay away from that stuff myself. H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
05-21-2019 | #9 |
I would suggest that you remove the top. Place your left foot in first, then left hand on the frame rail nearest the back of the seat. Lean in and put your right hand on your console glove compartment and hoist yourself in tucking the right leg.
Getting out is always the hardest. Open the door wide open. Left hand on the door sill frame rail and bring your left leg out and on the ground. Lean out to your left and place your right hand on the console compartment. Lift up with both hands and slide onto the frame rail. Bring your lead foot out and around on the ground. Lean forward with your right hand on the steering wheel or windshield puller and stand up. If the last part is still difficult, if you are in your garage, you can suspend a rope with and attached triangle and use that to hoist yourself out. This technique is useful for any aging C4 driver[emoji41] Sent from my iPhone using ZR-1 Net Registry
05-21-2019 | #10 |
Im scheduled for RH hip total replacement end of July beginning of August. I've been worried that Id have to get a Z06.... I just got back into a ZR-1 just a year ago now.... I really want to stay in it! Im not even the right age to be needing this yet.... too many years of drywall work I guess...
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
