01-13-2008 | #1 |
Can someone ID this connector>>>
Function?
Thanks much Michael |
01-13-2008 | #2 |
Re: Can someone ID this connector>>>
Diagnostic link for when the car was going down the assembly line.
01-13-2008 | #3 |
Thanks...makes sense...a pre OBD II type port?
M |
01-13-2008 | #4 | |
01-13-2008 | #5 |
It doesnt do anything its function is just what jeff said.
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
01-14-2008 | #6 | |
When I've had my car dyno'd, the tach signal was picked up there. And I used the ground from it when checking injector resistance through the ECM harness.
01-14-2008 | #7 | |
I mean that actual conector the one that plugs into that harness right there does nothing it is a dummy conector.
01-14-2008 | #8 |
Technically it is called the "Electronic Ignition Diagnostic Connector".
It's labeled as G|F|E|C|B|A G - Goes to coilpack base F - Tach out E - Bypass Input C - Ignition Control Input B - Reference Lo A - Reference Hi The ALDL is located beneath the drivers side hush panel. |
01-14-2008 | #9 |
Thanks all...more info for the library!
Michael |
01-14-2008 | #10 | |
