Old 05-03-2019   #1
Rumblin70SS396
Default Next question.......ABS light.....how to disable?
Hello all,
My car had its ABS disabled years ago when the front brakes were installed. Any way to get rid of the unsightly service ABS light in the info center?
As always, thanks in advance!
Tony
Rumblin70SS396 is offline   Reply With Quote
Old 05-04-2019   #2
BigJohn
BigJohn's Avatar
Default Re: Next question.......ABS light.....how to disable?
Pull the light bulb
Old 05-04-2019   #3
gbrtng
gbrtng's Avatar
Reconnect the ABS ... on my 91 there is a power connector in the cubby behind the driver's seat. There is no good reason to disable the ABS unless the system is defective and no parts are available.
Old 05-05-2019   #4
Rumblin70SS396
Thanks guys, I don’t see a way to connect it back up since the original front brakes are long gone.
Old 05-05-2019   #5
gbrtng
gbrtng's Avatar
has the ABS controller been removed too?
Old 05-05-2019   #6
Um, ABS sensor is in the bearing assembly, my front OEM brakes are long gone too, my ABS are fully functional still. Get yourself a Factory Service Manual. It will prove useful
Old 05-05-2019   #7
Ccmano
Ccmano's Avatar
I was going to say exactly that. The brake calipers have nothing to do with the sensors unless the sensors somehow interfered with the mounting of the calipers, but I can’t imagine that. I’m guessing there was some other reason the system was deactivated. Everything is fixable.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 05-05-2019   #8
Rumblin70SS396
Thanks guys I am still new to this car. I do see where the wires mount to the hub. I saw a loose connector and I assumed it was for the ABS.
That being said, if the ABS is behind the passenger seat in the compartment the whole unit has been removed.
Old 05-05-2019   #9
ABS is behind the Driver Seat, not the passenger seat
Old 05-05-2019   #10
Ccmano
Ccmano's Avatar
Under the tray and possibly some insulation.
H
