Old 04-25-2019   #1
Default WTB crank sensor connextor
I am looking for the 3 wire crank sensor connector found on the Ignition Module. I can find the harness side but I want the module side connector.. thanks
Old 04-25-2019   #2
spork2367
Default Re: WTB crank sensor connextor
https://www.jerrysgaskets.com/connec...-1990-95-12b5/
Old 04-25-2019   #3
Thanks but I need the IM side of the connector
Old 04-26-2019   #4
spork2367
I guess I'm unclear as to what you're looking for. The connector in the link is the connector that plugs into the left rear of the module. The connector on the module is molded into the entire case.
Are you just looking for a female connector that would match the cases connector?
If so, it's this one:
https://theelectricaldepot.com/weath...0ae6902b383fa4
Old 04-26-2019   #5
https://www.whiteproducts.com/fusible_link_wire.shtml
Go to the website and download online catalog. Looks like Metri-pack 1508.
Old 04-26-2019   #6
Yes I want the female connector to match the connector on the harness..
I have the one you posted (series 150 and I don't believe it fits.. I will check again, but if I recall it is too wide
Yun,
1508 is the harness side connector, yes, it is a series 150.2 pull to seat. I have not been able to find the female mate to it, that is what I need
essentially I want to plug it into the harness
Old 04-26-2019   #7
http://www.dstgateway.com/ACDelcoConnectorsV2/#/catalog
Also check PT 2353.
Old 04-26-2019   #8
that might b too wide, but again, I need the mate. I think I might just have to cut the harness, and use the 150 series, then make an 'adapter' to the OEM Crank sensor connector..
Old 04-26-2019   #9
It's tough to tell sometime looking at the catalog.
Are you looking for the female side? For your custom ignition module?
Old 04-26-2019   #10
Yes
