Old 04-09-2019   #1
Rumblin70SS396
Default Hard to Start...
My 90 Z always take a little bit to start.......I crank it for about 5 seconds, let off the key then crank it again and it fires up. Is that something common with these cars or an issue I should look into?
Thank you,
Tony
Rumblin70SS396 is offline   Reply With Quote
Old 04-09-2019   #2
TX '90 ZR1
TX '90 ZR1's Avatar
Default Re: Hard to Start...
Seems to me that is a bit too long before it fires off. Might check fuel pressure with key on and bleed down rate after turning key off.
Be careful letting off the key before it starts. They are prone to backfire and blow off vacuum lines. More times than not this will result in a plenum removal to correct.
Kenny
1990 #442
Old 04-09-2019   #3
I turn the ignition to ON a few seconds (like 3-4ish) before rolling the starter. My '90 ZR-1 usually take a 2-4 seconds after the fuel rail is pressurized, depending on how long it was idle, before it fires up. My wife's 91 ZR-1 fires much quicker - only one or two seconds in most cases.
Old 04-10-2019   #4
lfalzarano
Never turn the key off until it fires up. I’ve had backfires that have blown out injectors twice. Other bad things can happen.
When I installed Marc H’s chip, if fires immediately. Also old gas can also contribute to the delay in firing up.
Old 04-10-2019   #5
Rumblin70SS396
Thanks guys......what are you all using for fuel pressure gauges? The old gas is almost out as well...
Old 04-11-2019   #6
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Simplest way to avoid trouble is to do exactly as he said!
Experience teaches you this!
Great advice!
Marty
Old 04-11-2019   #7
Got mine AND an extension hose so I can tape the gauge to the windshield to do dynamic tests at Harbor Freight.
Old 04-11-2019   #8
Rumblin70SS396
Paul,
I hate HF but I will head there this weekend! Thank you!
Old 04-11-2019   #9
Rumblin70SS396
Thanks again guys, I will time joe long it takes to start as well. Last thing I want to do is pull this plenum again as it was almost impossible to seal
Old 04-12-2019   #10
32valvZ
32valvZ's Avatar
Thats how I do it also... I just wait for the vac pump to shut off, then start it.
