Old 01-09-2008   #1
kdmranch
Default PCV Valves
I noticed that the PCV valve mounting hose was all punky on the 90. I was lucky enough to have one on hand. But while I have this apart I thought I would change the PCV valves also. Must I find LT-5 specific valves or can I just match them up by dimension at the local NAPA? Would the 91 have the same valves? Dont want the girls to get jealous of each other,
kdmranch is offline   Reply With Quote
Old 01-10-2008   #2
kenthompson
kenthompson's Avatar
Default Re: PCV Valves
Is "pucky" a technical term that I need to learn to work on my car?
Seriously, they say the valves have different springs in them so that they open up at different times. When I rebuilt mine, I just used the same valve on both.
kenthompson is offline   Reply With Quote
Old 01-10-2008   #3
bradslt5
there are definatly 2 different pvc valves . youd have to ask jeff if they really makes a difference on if you can use others also there is an order that they are placed
Old 01-10-2008   #4
Jeffvette
Part numbers are:
CV769C Left Hand side
CV913C Right Hand side
And the reason for two PCV valves from Graham Behan:
"Well as in most of the stories from the early days of development it is
a long'ish one. Yes the system is the way it is based partially on cost. The
fresh air recirculation type of system utilizing PCV'S was the way that most
GM products were and the way that the LT5 was specified. The problems with
this were that with the LT5'S relatively high output coupled with the lack
of internal crankcase volume the requirements for the PCV system was very
different from the norm . The engine exhibits very different characteristics
at part load/no load than it does at WOT, this is true of most engines but
the massive blowby at no load required a very different PCV characteristic
than the WOT condition. During the development process Allan Nobbs, of
Lotus, came up with a variable orifice PCV valve which was well suited to
the large changes in the engine. Well after the design was shown at one of
our many vendor meetings it was decided that tooling a completely different
valve was not on, so the system was changed to the current spec, using two
valves with differing characteristics in an attempt to establish a good
compromise. We can all see the results, the system actually exhibits reverse
flow at WOT."
Old 01-10-2008   #5
bradslt5
one question that I have allways had . does it really make a difference if you dont have the pvc valves in the correct order?
Old 01-10-2008   #6
bradslt5
if one was using the car for the strip only is there a better set up
Old 01-10-2008   #7
kdmranch
The term is "punky", not "pucky". I think that is a highly technical term, {as you had noted} that I am very sure I am not qualified to use.
Old 01-11-2008   #8
kenthompson
Oh yea, that's right. Pucky is what my DAD used to call a tube of silicone. Highly technical term
Old 01-11-2008   #9
Bob G
What is the better set up for the strip ? thanks Bob
Bob G is offline   Reply With Quote
Old 01-11-2008   #10
No, just as long as both valves are correct.
