Old 02-16-2019   #1
SLCKZR1
Default Help with oil pressure switch
It seems I have a significant oil leak at the oil pressure switch (for the dash light), on my 91. It's located at the bottom of the oil filter housing. I'm having a hard time determining how to remove and replace it. Do I need to remove the entire oil filter housing, or can I remove the oil cooler lines and access it from the front. Any help would be much appreciated.
SLCKZR1 is offline   Reply With Quote
Old 02-16-2019   #2
Default Re: Help with oil pressure switch
Removing Oil Pressure Switch TIPS
Old 02-16-2019   #3
SLCKZR1
Thanks for the quick reply. I guess I should have used the search option first. Apparently not the first one to leak. Thanks again!
Old 02-16-2019   #4
Ccmano
Along with the plenum pull and associated items the leaky oil senders are another right of passage for the ZR-1 owner. Enjoy your car.
H
Old 02-17-2019   #5
mgbrv8
Thank you Dynomite you beat me to it
Dave
