Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 NCRS Topics
Old 01-24-2019   #21
jrd1990zr1
jrd1990zr1's Avatar
Default Re: NCRS judging my 1990 ZR1
Originally Posted by JMO343 View Post
I do have the original pizza box with all items inside. All of my current rims have the stickers. I have the original window stickers but, no build sheet. Where is that located on the car? Or should just order a repo? Is this all needed for judging or just nice to have?
John #2331
On a low mileage car such as yours you should have a build sheet tucked up by the gas tank. There is also typically one in the frame which is not retrievable (left front near the base of the shock absorber). Some times there is one in the dash.
Drop your spare tire carrier and take the spare out. Lay on your back and look upwards, you should be able to see the build sheet. I am not saying you should remove it since it may tear when you try. If you look to the rear on the inside of the rear bumper fascia the assembly date is sometimes visible written in crayon.
I am not saying you need to have a build sheet or order one from the NCM. It is only needed if there is a concern by a judge with how your car was delivered from the factory. Think of it as something to have just in case. Documentation. It is not a judged item.
Besides the NCRS sticker attached to the car, make sure you have a battery disconnect and a fire extinguisher to get the 10 bonus points during Operations judging.
The biggest point loss area is in Operations. Make sure everything works. If you don't have a judging manual for the car you should get one to use for reference. If you are a NCRS member the judging sheets are available (or they used to be) on their website.
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 02-10-2019   #22
JMO343
Well I did find the build sheet when I removed the spare tire today. And stupit me I try to remove it. That didn’t turn out to well. I thought it would be easier then it really was. It came out half way and all ripped up. I should have just left it alone like I was told. So now I have half a build sheet. I did see the crayon mark on the rear of the car 5/1990 with an initial next to it.
Lesson learned today
John #2331
JMO343 is offline   Reply With Quote
Old 02-10-2019   #23
Mystic ZR-1
Mystic ZR-1's Avatar
Any writing in yellow tire crayon
on the spare tire?
Mine said ZR1, the date and
someone’s initials. Slightly worn.
The NCRS guys loved it....
Old 02-10-2019   #24
JMO343
Not really sure. Didn’t look that close at. I will have to drop it again and look closer.
John #2331
Old 02-10-2019   #25
JMO343
I just went and check my spare. It does have the yellow crayon marking on it.
ZR1 and someone’s initials
John #2331
Old 02-10-2019   #26
jrd1990zr1
jrd1990zr1's Avatar
Try to preserve the pieces of the build sheet you have. Might be an interesting exercise to order one from the museum (NCM) for comparison purposes. Just a thought.
Old 02-10-2019   #27
JMO343
I saved it and all the pieces and placed them in a zip lock bag.
John #2331
Old 02-11-2019   #28
kr1276
Sorry. Also have green bag with the spare lug nuts and the locking lug nut socket.
John #2331
John,
Could you send a pic of the green bag with the number and also of the tire gauge?
Thanks,
Keith
90 #331
kr1276 is offline   Reply With Quote
Old 02-11-2019   #29
JMO343
Sure can. Send me your email. I have the bag photo already. Just need to take one of the tire gauge.
John #2331
Old 02-11-2019   #30
kr1276
John,
kr1276@aol.com
Thanks!
Keith
90 #331
