12-12-2018 | #21 | |
Re: The most common but most unrecognized oil leak
http://www.zr1netregistry.com H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. Last edited by Ccmano; 12-12-2018 at 06:27 PM. |
12-14-2018 | #22 |
deleted
12-16-2018 | #23 |
I found to be the easy from on top.
Remove Oil filter housing, remove right side motor mount nut, lift motor. Plenty of room Pete
12-16-2018 | #24 | |
I do not like to remove oil filter housing (another oil mess) and having to replace that gasket also. Unless Oil Filter housing is leaking From the bottom...…. Two 6mm x 16mm Flange Bolts installed in Oil Pressure Regulator Valve Cover (10mm Heads) replacing original 6mm x 16mm (8mm Heads) Bolts. Top 6mm Bolt shown before tightening with 10mm Box Wrench Post 249 - Oil Pressure Regulating Valve Cover Plate See Also...……. Potential Oil Leaks and the OPRV Cover Plate
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-07-2019 at 01:14 PM. |
02-05-2019 | #25 |
Hey all, I think I too have this issue. I noticed that I have a bunch of oil gathering under the passenger side of the engine and is slowly seeping.
I've read this post a couple of times, but am left pretty confused as there seems to be a couple of ways to fix this. I appreciate all the different and creative way that we all tackled this one. Is there a consensus on the best, easiest most effective way ?
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker |
02-05-2019 | #26 | |
As far as I can tell there is no easy way to get these tightened up. It was the most challenging leak I had on my '90, but am proud to say it is bone dry now. (Fingers crossed!!). I could never bend the correct way to get on the bolts from the top. Finally got the car up and removed the frame braces so I could see the area where the cover was. Took the longest ratcheting box end wrench I had, hooked another box end to it and tightened the bolts. The bottom one was quite loose. The top not so much. I did not attempt to change the bolts as my body does not contort as it used to. Just tightening mine made it dry and it has remained that way for nearly a year. Good Luck!!
Kenny 1990 #442 |
02-06-2019 | #27 |
Thanks- I'm going to tackle (again) tonight and see what I can get accomplished.
02-06-2019 | #28 |
Bill, what also helps for access is to undo the lower engine mount nuts and lift the engine by and inch or two. If your removing the “K” members (frame supports) you’ll be undoing the engine mount lower nut anyway.
Have fun, H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
02-06-2019 | #29 |
Oh, Jeeeeez.... not looking forward to that one.
I am able to get my fingers on it, by contorting my body and right hand. I can feel the bolt heads but that is about it. I'm wondering what is "better" doing the "k" frame or removing the oil pump. Sure the oil pump is messy but I have a mess going already. I looked through the FSM last night and found no reference to this fix. Marc Haibeck mentioned this problem in one of his posts. He said he raised the engine a bit and did the repair by feel. Not much more information than that. I did remove the inner fender well plastic and was able to put some light "down there" I'm going to try (pray?) fishing a long socket extension with some universals through the "gap" and the "feed" with my right hand the 8mm onto the bolt and twist with my left hand. That's the plan from my work desk at the moment....... I'm blessed with big hands and PopEye forearms so repairs like this are miserable.
02-06-2019 | #30 | |
H
