Old 12-08-2018   #1
Kwood
Default 90 Z cranks but will not start
I drove it to work, would not start to go home. Got a new battery, still cranks but will not turn over. Any ideas?
KWood
1st Time Owner
1990 ZR-1[SIGPIC][/SIGPIC]
Kwood is offline   Reply With Quote
Old 12-08-2018   #2
Why a new battery?
the starter turns the engine over but engine does not fire?
Check INJ1 fuse.
Old 12-08-2018   #3
BigJohn
BigJohn's Avatar
Default Re: 90 Z cranks but will not start
Fuel Pump?
Old 12-09-2018   #4
Kwood
Yes. Battery was low, thought it did not have enough amps. I checked the fuse, it looked ok. Fuel pump was my next guess. Roll start would not work then, correct?
KWood
1st Time Owner
Old 12-09-2018   #5
mhobtr
still cranks but will not turn over. Sent from my iPhone using ZR-1 Net Registry
This is confusing. The starter spins the engine or not? I think you're saying the engine spins but does not start.
Quick check is to spray starting fluid in the throttle body and crank the engine. If it fires and stops, you have a fuel problem. If it doesn't fire, you have an ignition problem.
mhobtr is offline   Reply With Quote
Old 12-11-2018   #6
Kwood
Correct. Will do that. Thanks. Sorry, for the confusion.
KWood
1st Time Owner
Old 12-11-2018   #7
Ccmano
Ccmano's Avatar
Follow the FSM diagnostic tree to figure this out. Otherwise it’s just a shot in the dark. There are multitude of things that could cause this.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 12-13-2018   #8
Kwood
Thanks for the info. Starter fluid started the car, but did not keep it running. Guess I’m looking at a fuel problem.
KWood
1st Time Owner
Old 12-13-2018   #9
mhobtr
Now you can start going down the Chart A-7 posted above.
Have you checked the fuel pressure with a gauge?
Old 12-14-2018   #10
Kwood
No. I bought a couple of the suggested fuel pumps and am sending to the local Vette mechanic to let him run the diagnostics. Would love to say I’m a DIY guy, but I don’t have that equipment. Or a garage, after the divorce. But, I still have my Z, so that’s something.
KWood
1st Time Owner
