Old 12-06-2018   #51
tpepmeie
Default Re: A tuning tale: BLMs say lean, plugs say rich
I’ve run Bosch IIIs in my engine without problem. Granted that’s with 93-95 injector housings. Why do you think they won’t fit?
Todd
____________________________________
*** our email address has changed!
info@pepmeierengines.com
pepmeierengines.com
Friend us on Facebook too: www.facebook.com/profile.php?id=100011443683384
Pepmeier Engine Development
Old 12-06-2018   #52
Todd,
I have the 90-92 IHs. The 93-95 IHs use injectors that all seal at the tip like the secondaries do on the 90-92 IHs. I need injectors that also need to seal using the Oring in the IH secondary injector boss groove. The Bosch IIIs are narrow body injectors.
Currently thinking about either the Delphi units or trying to determine if Accel has changed the design of their injectors to eliminate the plastic aerator. My injectors are 10+ years old.
Bosch IIIs v Delphi units for 90-92 IHs.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 12-06-2018   #53
Ccmano
Ccmano's Avatar
I assume you’ve looked here for compatibility. Ford and Bosch/Ford injectors come in 22lb versions and they fit.
http://users.erols.com/srweiss/tableifc.htm
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 12-06-2018   #54
Jagdpanzer
Jagdpanzer's Avatar
With the Bosch III form looks like any dimensional compatibility issues could be easily solved with specially machined sleeve bushings for the primary injectors.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-06-2018   #55
tpepmeie
That would be excellent. They really are a fantastic choice. The design IV are similar form factor, and even better. But the full specs are not usually available. The IIIs in most cases have Ford motorsports specs published, one just needs to convert the specs from Ford to GM, which is not trivial.
Todd
pepmeierengines.com
Old 12-06-2018   #56
I still have my FIC rebuilts.. 10 years
Old 12-06-2018   #57
Phil,
Actually I investigated this w both Southbay and FIC. There is a sleeve that is used for the Bosch IIIs on L98s which they both provide. However, they both told me it would not work for the 90-92 IH due to the need to seal the primary injector w the O ring in the primary injector boss. It will work for the 93-95 IHs as Todd or Jeff are using.
So I decided to go w the new Delphi injectors which, based on FIC pricing, are competitive w the Accels. I tend to lean towards use of OEM level quality rather than aftermarket. They’ll also be providing me w “deadtime” values to be used in the Voltage Bias tables. And I appreciate that the injector set will have been flow matched to +/- 1%. That provides additional value for me.
Here’s the video FIC posted regarding modifying Bosch IIIs for the L98.
https://youtu.be/XaYtP4l5A_4
Here’s FIC discussing use of Bosch IIIs for 90-92 IHs
https://youtu.be/OABElyDRicU
Old 12-07-2018   #58
Karl
Karl's Avatar
Dennis,
Glad u jumped in. I was going to ask u what ur using?
Don’t have answer on new Accels. Maybe someone else has info.
If you zoom in on the tip of these new Accell injections in this thread the tip looks the same.
http://www.zr1.net/forum/showthread.php?t=29954&page=2
1985 L98 Blue On Blue *Sold*
Old 12-08-2018   #59
Top Toy
Top Toy's Avatar
Re the voltage bias, I assume you're referring to the pulse width correction vs. supply voltage? I did not get anything from FIC and am still using the stock table. Have you seen significant differences with other injectors?
'95 ZR-1, aqua/gray, #167
Old 12-08-2018   #60
Dennis,
I requested the Bias values from FIC and was told initially I didn’t them and to just use stock values. I’m from the school that says the info going into the ECM NEEDS to be correct in order to get the most accurate tune. I did this w the Accels and the VE tables were different for conditions such as Decel, Idle and low speed part throttle where the Bias plays a bigger role in the PW calc. I can let u know when I get them.
