12-05-2018 | #1 |
Loud popping on take off, screeching when loaded up.
Hey y'all, got a loud pop that you can feel through the car when taking off from a stop, also turning under load. Also has a sound like sketching, or rubbing when I load the drive line with anything more than a little throttle. Sounds a lot like a brake pad tattle tale touching the rotor, except it gets louder with more throttle...
With the car in gear and the e-brake off, there is a popping noise when I rock the car back and forth. Got up under it and it sounds like right side u-joit or maybe the differential. The sketching under load points to a diff going out, but I don't know if a half shaft u-joint will do the same thing. Anyone had this issue? Help troubleshoot? The Juan is going to be down for awhile. Going to install new u-joints in the right rear, and a new hub, have had the parts for awhile. Also had another intake backfire, when I pull the upper plenum this time I'm going to replace the lower gaskets, got a vacuum leak there sucking in oil and making me smoke. Jay Sent from my SM-G960U using ZR-1 Net Registry mobile app
1991 White ZRJuan #1616 Mileage: 56K Sept-14 -- 113k May-18!!! God Damn I Love This Car! |
12-06-2018 | #2 |
Re: Loud popping on take off, screeching when loaded up.
12-06-2018 | #3 |
12-06-2018 | #4 |
Sounds like either your bearing hubs or half shaft u-joints, or both, are well on their way out. While at it also be sure to check out the differential.
