Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Cleaning and Waxing
Old 10-02-2017   #21
conesare2seconds
Default Re: Underhood and suspension cleanup
Hi, Jeff. For cleaning I used Super Clean concentrate in a spray bottle mixed 4:1 with distilled water. Super Clean is available premixed or the concentrate is in a gallon jug. The concentrate is very economical.
I sprayed the painted and plastic surfaces with distilled water, then Super Clean mix and agitated the dirt with a boar's bristle brush, followed by a rinse with more distilled water. Some really dirty surfaces got a light scrubbing with a blue non-scratch Scotchbrite pad or a toothbrush. Suspension surfaces were scrubbed with a small wire-bristle brush, followed by a once-over with Mother's Metal Polish.
For a little "pop" after cleaning I used Stoner's Trim Shine from an aerosol can. It's safe for all surfaces and I find it easier to work with than the spray bottle that's also available. Wipe off any excess with a microfiber towel. Trim Shine is water based and doesn't leave sticky residue. The finish isn't high-gloss, it just looks rich and new.
Old 10-02-2017   #22
shawn8492
Originally Posted by conesare2seconds View Post
Hi Shawn. I'm in Little Rock. Would love to make the Eureka event but could only make it for a few hours Friday due to my work schedule. On the fence about that. Where are you located?
I am just outside of Fort Smith, in Alma. I am going up on Friday if it doesn't rain and spending the night.
Hope to see you there,
Shawn
shawn8492 is offline   Reply With Quote
Old 10-03-2017   #23
George45
Nowineed toclean my 91. Its only got 12k on it but has some dirt ssccumulation. I suspect its never been cleaned.
Sent from my SM-T817V using ZR-1 Net Registry mobile app
George45 is offline   Reply With Quote
Old 10-03-2017   #24
George45
Originally Posted by George45 View Post
Now I need to clean my 91. Its only got 12k on it but has some dirt accumulation. I suspect its never been cleaned.
Old 10-08-2017   #25
ZR1North
Great effort - great results! Well done.
1991 ZR-1 (SN666) - Haibeck 510; 410s, Corsa, SW Headers; Hurst SS; DeWitts Rad; RC Injectors; LEDs throughout; `93 MF Sawblades
2016 Z06 - Stock
1971 Stingray 454 LS5 - Sold
ZR1North is offline   Reply With Quote
Old 09-08-2018   #26
Crusin
Crusin's Avatar
You certainly did a lot of work cleaning under the hood and the suspension. The results speak for themselves. Whoever sprayed that plastic coating on it should be whipped for there stupidity.
Crusin is offline   Reply With Quote
Old 11-19-2018   #27
32valvZ
32valvZ's Avatar
Looks nice so far... Ive done this process on all my C4's...
Suggestion for you: Get yourself a wire brush that will fit into a cordless drill and knock some of the rust off the rotors and spray the hats and the vented area with some hight temp black.... It will look really good in comparison.
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 11-19-2018   #28
Crusin
Crusin's Avatar
Good suggestions for cleaning under hood and suspension. You did a great job.
Old 12-03-2021   #29
Figure8it
Figure8it's Avatar
This represents over 40 hours of cleaning time
Your car is looking fantastic! I've just started the process of cleaning mine and I'm very envious of how nice you've been able to get things. BRAVO!
Figure8it is offline   Reply With Quote
Old 12-03-2021   #30
conesare2seconds
Just do a little at a time. Cleaning is cheap and very rewarding. My latest project is paint correction. I?ve gotten good results with a DA polisher but really need to suck it up and wet sand the panels I haven?t finished.
I agreed with the suggestion about the brake rotors and installed Stoptech rotors this spring with nicely finished black hats, Hawk HPS pads and stainless brake lines.
