Old 11-17-2018   #11
jss06c6
Default Re: Tuning Question
Originally Posted by Top Toy View Post
Did you optimize ignition timing while on the dyno? Advancing the spark, within limits, should also reduce the unburned fuel.
Sent from my HTC U11 using ZR-1 Net Registry mobile app
Took it to the knock limit..
Sent from my XT1585 using ZR-1 Net Registry mobile app
Old 11-17-2018   #12
Originally Posted by jss06c6 View Post
Dom,
I'll need to confirm from John Boyd's notes. I believe they are FIC.. the issue shows up under a 10% load on the Dyno sustained at 4500-5000 rpm.
Yeah so right around torque peak. This is where u will see knock occurring. It may have little affect at that rpm, but is the proper Injector Bias set in the table?
Not sure FIC provides that altho they should..
