11-16-2018 | #11 | |
Re: LED hedlamp install
Any chance u have pic of where relay is on passenger side?
11-16-2018 | #12 | |
Nowhere does the stock wire between the dimmer switch and the relay come close to the area of the fog lights themselves. When you look at the schematic, it all becomes clear. OR, if you don't want to permanently disturb the stock wiring, NOR change the operation of the fog lights (turned OFF when the Hi beams are activated), the LOAD RESISTOR option is about you only option. However, anytime you use a load resistor to maintain original control of the lights, you are not reducing the load on the alternator. Aside from operating the fans, the headlights are a significant load. So, if you don't mind isolating the fog light operation from the (stock) headlight operation/configuartion, you CAN reduce the load on the alternator by grounding the (coil) portion of the fog light relay. P.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 11-16-2018 at 12:57 PM. |
11-16-2018 | #13 |
So if you have a problem with your lights driving across Kansas; can you stop at Autozone to pick up replacement lights?
11-16-2018 | #14 | |
But, the answer is "Of course you can buy stock type sealed beam light(s). That will get you by until you can run down a replacement. But, you raise a valid point about the LED headlight market being flooded with virtually every imaginable LED configurations!!
11-16-2018 | #15 |
Yeah or just bring the spare set of Halogens you just replaced.
11-17-2018 | #16 |
Chipsets by CREE if used in a particular headlight pair gives by association a certain level of confidence. They've been in the LED biz for decades, and are the leader in the technology.
Time will tell all. But, compared to incandescent bulbs (at least those producing the same amount of light), the LEDs are hands down winners in the service life comparisons. But, as mentioned before, the LEDs don't run near as hot as HIDs or incandescent sealed beams. That means there may be issues with ice such as freezing rain building up on the lens. (Course, everyone knows that it's against the law to be driving a Corvette is such conditions in the first place. And, the Corvette Police will give you a ticket for driving in such weather anyway!) I don't loose any sleep worrying about driving in a sleet storm... .
11-19-2018 | #17 | |
There were only two on my 90 and my 91. The FSM is wrong
11-22-2018 | #18 |
Dittos. Same on our 90 and 91 Zs: TWO only.
Note the headlight housing is notched in two spots ONLY.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 11-22-2018 at 09:03 AM. |
11-22-2018 | #19 |
Thx guys. Good to know.
11-22-2018 | #20 |
Wow!
You drive these cars after dark? What's next? Driving in the rain? Marty |
