Old 09-14-2018   #1
Jim Stanley
Default Running on 7 Cylinders
My 1990 was running great until today. Note: The car has 31K miles and I drive it about 1500 per year. When I started it up I could detect a miss. As I drove it the miss became more apparent. All of the gauges read normal and there were no warning lights. At idle it made a helluva racket, especially with the AC on. I stopped at a local shop and the mechanic said I was getting spark to all 8, so probably not a coil. He thought a fuel injector had gone bad. Sounds reasonable I suppose. A couple of questions for you seasoned Z folks:
1) Can a clogged injector be cleaned?
2) Do they all have to be replaced? (I am going to try to find out if they were changed by the previous owner).
3) Why would the AC cause more rattle?
4) If not a fuel injector issue, then what are some other probables?
5) Would it make sense to check compression and spark plugs?
Thanks for your thoughts and recommendations.
Jim Stanley is offline   Reply With Quote
Old 09-14-2018   #2
jss06c6
Default Re: Running on 7 Cylinders
If it's one cylinder and spark is good, your mechanic is probably spot on, especially with very little driving.. do have the original injectors? If so, ethanol is probably part of the problem..
Sent from my XT1585 using ZR-1 Net Registry mobile app
Old 09-14-2018   #3
Sometimes but not recommended on 90~92 w/original injectors
You should replace all 16 with new.
Additional load on the engine
Being a 1990 & spark on all 8, it's 95% likely injectors
Plugs; yes, just in case, compression; not something that would fail suddenly.
Jerry
Old 09-14-2018   #4
Jagdpanzer
Jagdpanzer's Avatar
In light of the fact it’s a 1990 model year good chance it’s a bad fuel injector. Here are instructions how to check the coil resistance on the injectors without having to remove the plenum:
http://www.zr1specialist.com/HAT%20W...in%20Place.pdf
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-14-2018   #5
Jim Stanley
Thanks for confirming.
Old 09-14-2018   #6
Jim Stanley
Thanks Jerry, for the additional information!
Old 09-14-2018   #7
Jim Stanley
Great article, thanks Phil. I will try it out.
Old 09-14-2018   #8
Ccmano
Ccmano's Avatar
Jerry
What Jerry said is 100% one the money.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
