Old 07-23-2018   #31
Regimof3
Default Re: Building a beast...doing a 391
Do you have a projected date?
Regimof3 is offline   Reply With Quote
Old 07-23-2018   #32
EvanZR1
EvanZR1's Avatar
When it gets done? Seriously though, probably another 1-2 months. I've got other items (coil overs, AC fix, gauge cluster rebuild, shifter install, shift light install and a few other items) that are being done too. Sucks not to have the car this long, but worth it to get as much done as possible at once. With entire exterior repaint and interior redo, the car will now be virtually complete restoration with all the engine work and other fixes.
[LEFT]Evan
2024 Z06
SOLD - 1991 Admiral Blue ZR-1
SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP
SOLD - Steel Blue 91 391cid ZR-1 #391
SOLD - Black 91 ZR-1[/LEFT]
Old 08-09-2018   #33
EvanZR1
EvanZR1's Avatar
Engine assembly in progress:
[LEFT]Evan
2024 Z06
Old 08-09-2018   #34
Jagdpanzer
Jagdpanzer's Avatar
Looking good!
What compression ratio?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-09-2018   #35
Jitse
Nice closed deck !
Jitse is offline   Reply With Quote
Old 08-09-2018   #36
onetinsoldier
Looks nice ! Not sure what oil they told you to use to break it in , if they haven't , you might want to ask . A lot of builders use conventional oil, then after break in period, you can switch to synthetic . Its just builders preference !
onetinsoldier is offline   Reply With Quote
Old 08-09-2018   #37
Love that closed deck !!!!
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 08-10-2018   #38
EvanZR1
EvanZR1's Avatar
Can't find the info now, but I believe we were talking 11:1 (or slightly over).
[LEFT]Evan
2024 Z06
Old 08-14-2018   #39
EvanZR1
EvanZR1's Avatar
So I was off a little, talked to Pete and we're doing 12:1.
[LEFT]Evan
2024 Z06
Old 08-14-2018   #40
[I][COLOR="Blue"]Good carz, good food, good friendz = the best of timez![/COLOR][/I]
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
