05-27-2018 | #71 |
Re: Working on the 74.....
If GM had built the ZR-2 Corvette in the nineties with the big block. Which would you have chosen? |
05-27-2018 | #72 |
The play is already set on the cam.....as mentioned above. ..
Copy on the distributor gear.... Cam was degreed with lifter.... Will post the specs for the cam.... Automatic......going with a 2400 stall.....deciding on B&M Holeshot......or TCI I have 3.08 gears..... Btw.......great run!!![emoji16][emoji16][emoji106] Sent from my SM-G935P using Tapatalk
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member |
05-27-2018 | #73 |
John......at the time I would have chosen the ZR-2 Big Block.....mainly because of the cost factor......I couldn't afford the C4 ZR-1 at the time.....although I was trying to find ways......lol
06-27-2018 | #74 |
Engine is starting to look like an engine once again.....getting there......
20180621_123056.jpeg20180621_123111.jpeg20180621_124104.jpg20180621_174151.jpeg Sent from my SM-G935P using ZR-1 Net Registry mobile app
06-27-2018 | #75 |
More progress.......20180624_122536.jpg20180624_144056.jpg20180624_160053.jpeg20180624_163053.jpeg
06-27-2018 | #76 |
06-28-2018 | #77 |
More progress today.....20180628_171055.jpeg20180628_171117.jpeg20180628_173447.jpg
07-20-2018 | #78 |
Looking real good, Roadster. Lots of work going into that project!
I've been detailing my '79 L82 engine compartment on and off for a few months now. I had detailed it about 8-9 years ago, but some of the paints didn't last, and other areas needed attention. One learns what works and what doesn't over time. For a Satin or Gloss Black finish on various parts, including bolts, screws & washers, I found VHT epoxy paints work well. VHT Roll Bar & Chassis Satin Black paint for most parts for a Satin Black sheen, and VHT Epoxy Paint Gloss Black for a glossy sheen. After letting dry for at least 48 hours, a week if possible, I've used a curing process by sticking the parts in the oven on 150 degrees for 30 minutes. This, hardens the epoxy coating to the point where the metal socket used to screw the bolt/screw & washer down doesn't mar the fresh paint at all. Also, the red powder coated valve covers had lost a little of the shine and had some spider webbing. Chemical Guy's V36 Optical Grade cutting polish on a microfiber rag worked better than anything else I tried. They have a pleasant shine again. Anyway, I simply need to put it all together, and quit doing another "while I'm at it..."! Here's a pic of the '79 Vette L82 engine (original) detailed and ready for the Air Cleaner.
'94 ZR1 LT5 - Dark Red Metallic '79 L82 4-speeds of fun '96 LT1 Borla, H-pipe, TB, CAI (Sold) "An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton |
07-22-2018 | #79 |
Thanks G-Sting...….will take notes on your findings.....thanks for the compliment…..will post more pics.....from the cell.....moving along.....keeping me busy along with the Z A/C compressor.....better busy than not busy....lol
07-22-2018 | #80 |
More progress made......small parts detailed....20180708_142133.jpeg20180710_121928.jpeg20180710_123354.jpg20180710_131220.jpg
