Old 05-03-2018   #21
spork2367
Default Re: secondary injector module/ecu
Originally Posted by tpepmeie View Post
The wiring pinout is different between 90 and later years for both the power key (as mentioned), including the power key lamp, and the knock sensor. Later years also had EGR, but I doubt anyone running the MS would care about EGR.
Then how are the ECM's interchangeable as per Marc?
Old 05-03-2018   #22
Because the OEM ECMs have enough inputs and outputs..
So the PROM then Defines the ECM's inputs and outputs.
if you mapped it out the Power key, knock and EGR use pins that are unused on the 1990..
Functionality was there in the ECMs, just not used
Old 05-03-2018   #23
spork2367
Question Re: secondary injector module/ecu
So one would think that would be even easier on the megasquirt ecu. Which begs the question, what is different on their ecu between cutoff. I sent them an email.
Old 05-04-2018   #24
jss06c6
Originally Posted by spork2367 View Post
They don't have access to the info needed to fix the ccm issues and likely never will, nor will it be worthwhile to invest the time due to the low demand.
I believe these are for sale any time, you just may have to wait until they get a couple orders before they build. I know when mine was built they had 2 or 3 orders. I ordered mine in March of 2016. Took about 2 months to get, with some communication issues along the way.
I hope to get it up and running this summer.
Torqhead out of Canada has the CCM data stream figured out for L-98, but they don't have the engine control for LT-5 secondary injector control done (low demand). I've been trying to get MS to talk to Torqhead so that "they" can solve the CCM issues. Have not had any success so far.
I had mine out of the box once, put it on my 91 and it had a very long crank time until it started and ran like crap. Haven't fooled with it since.
In what aspect? To the best of my knowledge, the only things they hadn't worked out were the trip computer/mpg stuff.
Sent from my QTAIR7 using ZR-1 Net Registry mobile app
Old 05-04-2018   #25
spork2367
That would be awesome.
