Go Back   ZR-1 Net Registry Forums > General > Forum News
Old 12-31-2007   #1
A1990
A1990's Avatar
Default auto log out
Is there a way to stop this from happening?
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Treasurer
Old 12-31-2007   #2
Z Factor
Z Factor's Avatar
Default Re: auto log out
When you log in, just click the remember me box and you should not have any problems. However if you have done that and are experiencing the problem, check your cookie settings and make sure they are not being removed on an automatic basis.
Old 12-31-2007   #3
flyin ryan
flyin ryan's Avatar
i thought i had this problem solved a while ago. it is better than it used to be, won't log me out as fast, but it definatly still happens. with the recent talk about people coming over from CF i can't help but think things like this can't help. i'm not complaining, i'm pretty much used to it, i'm just sayin'...
Old 12-31-2007   #4
HADI-ZR1
i sill have this problem, after 5 - 10 minuts , i am auto log out!!
I dont like it!
I should always within 2-3 min. reload the page ! hmmm
Old 12-31-2007   #5
Z Factor
Z Factor's Avatar
Here I was thinking you had a unique problem. I didn't realize this was a common issue with other posters.
If the aforementioned solutions do not work, keep the faith as I will add this to the list when I contact the techs at vBulletin.
Old 12-31-2007   #6
HADI-ZR1
Good luck Z !
I use Opera browser and Firefox, but same problem, i even switch on all cookies.
