Old 04-23-2018   #1
TealZR1
Default LT5 Lettering Refresher
Anyone have any special techniques to repaint the lettering on the LT5 besides a very small brush and steady hands? Thought about painters taping them up as close as possible, than spray painting and immediately cleaning up with a citrus wipe any overspray before drying occurred. The original enamel should not me harmed with the option.
Would like to refresh them. Thanks!
TealZR1 is offline   Reply With Quote
Old 04-23-2018   #2
spork2367
Default Re: LT5 Lettering Refresher
I thought about using my vinyl cutter to cut high temp vinyl for it. I just have to take some time and draw it up in autocad and tweak as necessary.
Old 04-23-2018   #3
B17 Crew
What about using a liquid mask, such as what model builders use? It’s used to mask-off areas they wish to protect from overspray/paint. Liquid mask can be applied with a brush. Once its dry, spray paint letters, when painting is complete, the liquid mask just peels away.
Link to liquid mask:
https://www.hobbylinc.com/htm/div/div3000.htm
B17Crew
B17 Crew is offline   Reply With Quote
Old 04-24-2018   #4
As I recall, the factory just used high temp black barbeque paint. Don't know how they applied it though. Probably some sort of mask. --Bob
WARP TEN is online now   Reply With Quote
Old 04-24-2018   #5
Stillwater had a masking template and literally sprayed over the letters back and forth a couple of times.
https://www.youtube.com/watch?v=ZlTOfK0_INE
In the above video you can see the template which was lowered onto the top of the plenum about 3:21 and the hi temp bbq temp black paint applied
Old 04-24-2018   #6
tiegsd
tiegsd's Avatar
Hah! That's classic.
Sent from my SM-N920V using Tapatalk
1990 Black/Black ZR-1 #1155
Old 04-24-2018   #7
TealZR1
thanks to all who responded - will try the liquid mask.
Wonder how much that factory template would go for now?!!
Old 04-24-2018   #8
Lol if it was available we could buy it and treat it like the Stanley Cup teammates do after a win. JELLO 4 Cam 32 Valves letter shooters from member to member lol. GC
Old 04-25-2018   #9
The mask looks interesting; might give it a try.
I found using an artist's brush and acetone (aka fingernail polish remover) was the trick (for me).
After painting the recessed cavities and before the paint completely dried, stretching an old T-shirt dampened with the polish remover over my index finger, cut a perfect line between the flat surface and the vertical edges of the letters.
By avoiding much as possible getting too much paint smeared on the flat surfaces, I was able to paint the letters easily and quickly - knowing I could cut the letters with the acetone as a last step. Forget about trying to cut the letters with a steady hand and the atrist's brush: takes FOREVER! And, it was near impossible to cut the letters cleanly. Just paint 'em and cut 'em later is the ticket!
Old 04-25-2018   #10
Bob Eyres
Cool video, I wonder if that guy, briskly spraying those letters almost thirty years ago, could envision us old geezers today, our hands shaking, trying to paint them with a tiny brush..
Here's a laugh. On the YouTube site, next to that video, check out the clips discussing the new LT5. I saw two that use a pic of "our" old four cam LT5 to stand in for a picture of the new motor.
Well, if you don't have video of the new killer DOHC engine, pull a pic of the old one out of the archives. After all, it is the best looking Chevy engine of the last fifty years..
You can bet that the new one won't look nearly as good, more like Tupperware.
