Old 04-09-2018   #11
Default Re: EPROM/Display Panel Issue
Originally Posted by VisionOP8 View Post
Thanks man . The idle on the car is usually just below 1000rpm once its warmed up. I will research to find out how to scan for codes, I think that should really be my next step. I honestly have no idea how to do it and Ive seen things mentioning jumping connections with a paperclip. I will have to read some things again.
Bingo you prob have a vacuum leak 1000 rpms or just below it is way too high. Normal idle on an stock car is about 600rpm max.
Old 04-09-2018   #12
VisionOP8
Damn you're good! Okay man that sounds good to me, Im gonna get it checked out!!! You're too awesome!!!
VisionOP8 is offline   Reply With Quote
Old 04-09-2018   #13
Well your not out of the woods yet high idle could be a idle adjustment stuck IAC etc. but now you have some areas to look at
Old 04-10-2018   #14
jss06c6
Not sure I understand the comment that the power key is not functional in a 1991? My tune defaults to full power on start, but can certainly be changed back to valet mode with the key... ???
Sent from my XT1585 using ZR-1 Net Registry mobile app
Old 04-10-2018   #15
All the keys are functional unless deleted by the prom... normally to always on. The OP did not understand why the full engine power light did not come on in the DIC in his 91. That light only comes on in the MY 90 in the DIC. 91-95 ZR-1 indication of full power mode was by viewing the green led next to the valet key which indicated full power is on.
