Old 03-11-2018   #1
TX '90 ZR1
TX '90 ZR1's Avatar
Question Chasing oil getting out.
Never had any bad oil leaks, but I would see a drop or two at times hit the floor. Am working on all of Marc Haibecks recommendations to get it shut off completely.
First I checked all the easily accesible pan bolts. Some were a little loose. One was about ready to fall out!. Just this step helped a lot.
Would notice a small amount of oil beside the injector housing on drivers side. Removed the PCV 90 degree rubber grommet and saw the lip was folded as in Marc's pictures. Replaced it.
Only sign of leaking now is at right front of oil pan. Have the cross braces out to get to the hidden bolts and the 3 at the front. One front pan bolt was missing, but was suprised there was no oil leak around it. Of course I replaced it with a new one and tightened the others.
I think the oil pressure regulator cover may be leaking some. I can't seem to access it from the bottom. Marc's instructions say to lift right side of engine and access it from the top.
I guess my question is: What is the procedure for lifting the right side of engine?? Or does anyone have another recommendation for accessing the cover bolts ?
Kenny
1990 #442
Old 03-11-2018   #2
Default Re: Chasing oil getting out.
I could not get to Oil Pressure Regulator Cover from the top on my 95'
I got to it from the bottom and replaced Both 6mm x 15mm Bolts with 8mm Heads with 6mm x 15mm Bolts with 10mm Heads.
See item #3 Potential Oil Leaks and the OPRV Cover Plate
Old 03-12-2018   #3
TX '90 ZR1
TX '90 ZR1's Avatar
Thanks for the reply Dynomite.
Mine is a '90 so I don't have the EGR to contend with.
From underneath I think I can see the lower bolt on the cover, but there is a shield attached with 2 pan bolts that blocks access. The shield appears to have wiring attached to it.
It was getting late in the day when I got to this. I'll give it a fresh eye tomorrow & report back.
I really appreciate your input on my posts.
Kenny
1990 #442
Old 03-12-2018   #4
To lift the engine right side remove the passenger side motor mount nut and place a jack under oil pan with 2x4x6 pad between jack pad and oil pan. Lift on passenger edge of oil pan. You will gain a couple inches more or less.
On my 90' I reached in from the top front of the engine to get access to the two 6 mm bolts with an 8 mm hex flex head ratchet wrench as described in item #2 Potential Oil Leaks and the OPRV Cover Plate
Since such a tight area to work in with engine in car I removed each 6 mm bolt one at a time so I did not drop the cover plate or gasket. So...no permatex on that gasket but both 6 mm bolts cleaned and Blue Loctite applied.
Since the bolts and plate were so loose I figured correctly just tightening the 6 mm bolts with Blue Loctite would solve the oil leak and loose bolt problem (The gasket was stuck to the engine block and not the cover plate). I tightened the bolts by feel as I could not get torque wrench even close to that area unless engine is out of car. No more oil leaks in that area at all.
The BEST fix, however, is to replace those two 6mm x 15mm bolts having 8mm heads with two 6mm x 15mm bolts with 10mm heads as described in item #3 Potential Oil Leaks and the OPRV Cover Plate
Old 03-12-2018   #5
davekp
How long are these bolts?
davekp is offline   Reply With Quote
Old 03-12-2018   #6
They are 6mm x 15mm or 15mm long which is .59 inches
The Top bolt has a 8mm head and the bottom bolt has 10mm head which larger head is much easier to keep a metric socket or metric box wrench on.
I always use 6 pt sockets or box wrenches rather than 12 pt on ZR-1/LT5 bolts..
Old 03-12-2018   #7
davekp
are they coarse or fine thread?
Old 03-12-2018   #8
Look for a 6mm metric thread bolt. You are looking for a 6mm bolt 15mm long with a 10mm hex head (with flange).
A 6mm bolt I think only comes with a 1mm pitch.
https://www.boltdepot.com/fastener-i...ead-Pitch.aspx
Old 03-12-2018   #9
davekp
Thanks!
Dave
Old 03-12-2018   #10
TX '90 ZR1
TX '90 ZR1's Avatar
Default Chasing oil getting out. Status Update
Here's where I am now on getting things tightened up.
I wasn't seeing an easy access from the bottom, so thought I would try to get to the oil pressure cover from the top. I don't have real big hands and have worked in a lot of tight places, but was not having any luck. (Getting older and my body does not flex as it used to).
I got back underneath, got the wires unhooked from the shield and removed it. I could actually see the lower cover bolt. Was able to get a wrench on it and it was a full 2 1/2 turns loose!! Very tight quarters, but doable. I am going to tackle the upper bolt from the bottom tomorrow.
I am getting to the point that everytime I see a bolt or nut I put a wrench on it to make sure it is tight !!
I'll let you know how the top bolt goes. CHEERS !!
Kenny
1990 #442
