Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Member Rides
Old 02-28-2018   #21
Ccmano
Default Re: Bright red 1990 zr-1
Originally Posted by tommy View Post
Does anyone know why in the rear muffler one hole is closed? Attachment 7095
Prevents resonance. One of the reasons the 90’ systems are so restrictive.
H
Old 02-28-2018   #22
KILLSHOTS
New shoes
I hope that will be better traction, but I 'm wondering how they will works on wet Attachment 7085
Toyo R888...they stick like glue when it's dry, but I wouldn't use them in the wet unless you really need to.
Old 02-28-2018   #23
tommy
"Prevents resonance. One of the reasons the 90’ systems are so restrictive"
Do you know what will happen if i cut it, will be loud, sound will be better or worst...?
tommy is offline   Reply With Quote
Old 02-28-2018   #24
tommy
Thanks, I expected that it's better not to ride on a wet, so i will drive only in dry days
Old 02-28-2018   #25
Ccmano
It will drone (resonate) badly in low rpm ranges and possibly be slightly louder. You won’t like the drone.
Here a write up from “Warpten” on this subject. Bob does a nice job explaining it.
“This has been discussed over the years and relates to the construction of the muffler to reduce resonance. There should be several threads related to resonance that discuss this. One exhaust pipe goes into each muffler and two tailpipes come out, but only one actually flows exhaust straight out; the other is mostly cosmetic. If you cut one of your mufflers in half horizontally you would find that the rear two thirds of each muffler is a closed chamber with a 1 " or so diameter tube going into it. (Sometimes there is a small 1/2" dia. tube that goes through the chamber but doesn't connect with it to flow just a little bit a exhaust. Not sure why other than a bit more pressure relief).
The chamber is called a Helmholtz resonator and it engineered to be a specific shape and volume to cancel out one of the two main natural frequencies that our engines generate that create the intense resonance or "droning" under light to moderate load at 1800 and 3400 rpms that you have heard many with certain aftermarket exhaust systems complain about. The exact shape and size allow for sound waves of a specific frequency to enter the chamber, bounce around and cancel each other out. The center resonator also has such a Helmholtz resonator for the 3400 rpm frequency of 230 Hz; the mufflers deal with the 1800 rpm one of 120 Hz.
Sometime people drill out the dummy tailpipe thinking they will get better performance and a better sound. They are rewarded with the same performance and a loud droning at 1800 rpm. Bad idea. Corsa also uses Helmholtz resonators, and I suspect some newer ones of other makes now do too. Most of my research on this was done in the 90s; I am sure that several manufacturers hove found solutions to this problem. At the time, only the stock and Corsa systems tamed the resonance. Hope that helps--Bob”
Old 09-08-2018   #26
Crusin
Crusin's Avatar
Hard to beat that Bright Red for a ZR-1 Tommy. Nice to see you take TLC with it. We both have the same vette. Congrats enjoy the ride.
Crusin is offline   Reply With Quote
Old 09-13-2018   #27
tommy
Thanks, i saw yours, looks great too!
Old 09-13-2018   #28
tommy
Last weekend i was in big cars meeting in Poland, below you can see video how looks zr1 after correction of paint
https://www.youtube.com/watch?v=kGLIKYtkN08&t
Old 10-01-2018   #29
G-Sting
G-Sting's Avatar
The Z and the paint & polish looks amazing!
'94 ZR1 LT5 - Dark Red Metallic
'79 L82 4-speeds of fun
'96 LT1 Borla, H-pipe, TB, CAI (Sold)
"An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton
G-Sting is offline   Reply With Quote
Old 10-08-2018   #30
tommy
THX, winter is coming, so at this year i plan check brake system because i think that should work better. First i want to change brake fluid from DOT 3 to DOT 5.1, second i will change brake pads, so i hope thats enought
