Old 02-16-2018   #1
Default Engine Harness Variations
Considering purchase of extra engine harness. This is from a 90. Does anyone have knowledge of any significant deviations of harness build from one year to the next? If so, could you provide detail or where that can be found?
Old 02-16-2018   #2
Default Re: Engine Harness Variations
See attached.. I have info 90-93 but I assume 94-95 are the same as 1993
Old 02-16-2018   #3
Thx Jeff.
Old 02-16-2018   #4
Ccmano
Seems to me I read somewhere the harnesses on the very early 90’s was different from the later 90’s. I believe it was only the first few hundred cars.
H
Old 02-16-2018   #5
Hans,
The differences can’t be dramatic given the fact that any ECM can be used in any year ZR.
Old 02-16-2018   #6
Corvettes White
There should be a tag at one end of the harness. It will have the last few digits of the part number, George.
Old 02-16-2018   #7
For what you are looking to do it won’t matter
Old 02-16-2018   #8
tpepmeie
Hmmm. and what would that be?[emoji897]
Old 02-16-2018   #9
Todd,
I have an opportunity to pick up an engine harness for my car but from a different MY. Just want to check on compatability before purchasing.
Old 02-17-2018   #10
WVZR-1
In MY '90 there would have been 2 harnesses, 1 for C60 and the other for C68. A tag near the connector for C100 for C60 would be 0375 likely and C68 0376. There's an obvious visible difference where the C68 would plug into the Blower Control Module or the C60 just a conventional Blower Resistor.
