![]() Join Date: Sep 2016
I am 6-1 with a long torso. The top of my head with a ball cap on nearly touches the headliner. No way can I auto cross wearing a helmet with the targa installed. Has anyone ever lowered the seat mounts? How do the GM engineers do it on the Spyder?
![]() Join Date: Feb 2012
GM Engineers can not be over 5-1
GM engineer equals Small man syndrome huh?
But how did they get the seat so low in the convertible Spyder concept car with its raked low windshield? I have heard of racers fabbing a bubble in the targa for helmet clearance. Sent from my iPhone using ZR-1 Net Registry
![]() Join Date: May 2010
If you’re not set on the stock seat and power seat track you can lower quite a bit from what I researched on CF C4 section. I have a Corbeau A4 ordered shaved 1” bottom and also custom brackets to adapt to stock power seat unit which also lowers it a bit. If I were your height I would have to forego the power seat track for a manual slider to go even lower. The A4 seat (even shaved) is very comfortable to me, but I have not spent more than a couple hours at a time in them.
I have bolted seats to the floor with no track.
#6 | |
Thank you for the suggestions I sure wish I was 175 lbs! I would be 18 again!
![]() Join Date: Feb 2011
You can unhook the straps under the seat. I’m 6’4”.
BTW - The hard top, not the clear, is recommended for spirited high speed driving, since it is reduced body flex and potential damage to you irreplaceable windshield. Sent from my iPhone using ZR-1 Net Registry |
#10 |
![]() Join Date: Jul 2007
move the trapeze straps on the seat to the outer hooks not the middle that might help too
