08-07-2017 | #1 |
427 LT5
Hi guys I`ve got a question and hope to find some help here in the forum. I´m looking for parts to enlarge my LT5 to 427 cui. I asked Pete and he can regrind a set of stock cams for this engine modification. He told me that he would prefer a 4.00" stroke and 4.125" bore for this engine size with closed deck sleeves. so my question is: where can I buy the needed parts (crankshaft, rods, pistons, cylinder head gaskets and sleeves). I think some of you did this mod in the past, what would be the costs for the parts?
Thanx, Thomas
Best thing in life is a ZR-1 ride |
08-07-2017 | #2 |
Re: 427 LT5
Thomas,
you will need injectors as well. Have u considered just shipping the motor to the States?
08-07-2017 | #3 |
Re: 427 LT5
Yes, injectors as well, at the moment the engine is a modified 350 with fully ported heads, inj.-housings and plenum, no more secondaries, headers, stage 1 cams and 21 lbs FI prim. / 24 lbs FI sec.
I don`t want to send the engine to the States, I´ll build up the engine by my self.
08-08-2017 | #4 |
Re: 427 LT5
Here's where I'd start again :
http://www.lsmeng.com/Billet-Blocks2.html This endurance series block also has full water jackets. Integrated a standard GM bell housing so it can bolt up to most popular GM transmissions. Accepts a standard SBC crankshaft. Oiling changed to priority main. SBC motor mounts. Cross bolted main caps instead of two piece split crankcase. Accepts ZR1 heads and timing components. Can be driven on the street or road raced. Big money up front but in the end a better combination for less money.
Frank Urbo. NCM Lifetime member # 982 Registry Founding # 237 Last edited by FU; 08-08-2017 at 09:24 AM. |
08-08-2017 | #5 | |
Re: 427 LT5
AL. |
08-08-2017 | #6 |
Re: 427 LT5
WTH? When did that drop? I'm familiar with LSM, but didn't know they'd done that. Wonder if they bought the program and rights from Nelson.
That is pretty trick for sure. At least $10k to play I bet.
Todd ____________________________________ *** our email address has changed! info@pepmeierengines.com pepmeierengines.com Friend us on Facebook too: www.facebook.com/profile.php?id=100011443683384 Pepmeier Engine Development |
08-08-2017 | #7 |
Re: 427 LT5
On further review, that's got to be the Nelson design. I recall they converted the crankshaft to SBC and redesigned the oil flow to priority main. Nonetheless, it's too cool
08-08-2017 | #8 |
Re: 427 LT5
Closed deck LT5 block & a good stroker crank alone is north of 10k .
Frank Urbo. NCM Lifetime member # 982 Registry Founding # 237 |
08-08-2017 | #9 |
Re: 427 LT5
Oh I bet that billet block alone is $10-$14k. Just a swag.
I wouldn't have changed the oiling design, personally. But if I win that Mega Millions tonight, I'll have one
08-08-2017 | #10 |
Re: 427 LT5
