Old 06-18-2017   #171
Roadster
Roadster's Avatar
Default Re: TB removal and then some!!!
Carter, everything was in there, thanks again....
Sent from my SM-G935P using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 06-19-2017   #172
Roadster
Roadster's Avatar
Took the valves out of the coolant pipes to do a final paint coat and then clear them. Had one minor correction with the paint to be made, so I re sprayed them both, they came out good. Getting ready for the clear...
Also some valve info if anyone has an interest...
And made some minor clear passes on the plenum as I had one imperfection that really bothered me. You would be hard pressed to find it now...
final paint coat...
bleeder valve removed...uses a 1/2" wrench to install and a 5/8" wrench to open and close the bleeder....and some rags when bleeding the system...
back to the open paint booth for more clear...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 06-19-2017   #173
Ccmano
Nice work!
I might have missed it in the thread but where did get the valves and who makes them? They look to be nicer than most.
H
Old 06-19-2017   #174
Roadster
Roadster's Avatar
Nice work!
H
Thanks.....
Purchased from zoro.com they are $22 and change each. very well made...
clear is done....2 to 4 coats, depending on how you count them....lol
will let them dry for a few hours before reinstalling the bleeder valves with sealer.....getting there!!!
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 06-19-2017   #175
carter200
carter200's Avatar
Originally Posted by Roadster View Post
Thanks.....
Looks great!
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 06-19-2017   #176
Roadster
Roadster's Avatar
Originally Posted by carter200 View Post
Looks great!
Thank you Carter, and a good part of that "Looks great!" came from the work you completed.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 06-19-2017   #177
Roadster
Roadster's Avatar
I now have some options with the bolts from seeing them on another member's LT5. I now have both the SS replacement bolts, which I can use or the 12pt ARP bolts shown.....
Let's see, I cam mix and match, or do one side one way and the other another way!!! Either way all of them whichever one, will dress up the engine, at least the top half of the engine this season.....lol
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 06-19-2017   #178
gtcollins@maxnet.co.nz
gtcollins@maxnet.co.nz's Avatar
Hi looking good you won't be far from getting it going
Regards Glen Collins
Sent from my SM-G930F using ZR-1 Net Registry mobile app
gtcollins@maxnet.co.nz is offline   Reply With Quote
Old 06-19-2017   #179
Roadster
Roadster's Avatar
Thanks Glen, still have to work on the TB. Going to try to get that done this week. Still have some minor items to address under the plenum before I can put it back on.
Need to go out to the 74 at least 3 days this week. Have to make progress on that if I want to get it running by the Fall....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 06-19-2017   #180
Roadster
Roadster's Avatar
Valves threads sealed and reinstalled....
another view....ready to go...
1974 LS4 454 Vert
1974 L-82 355 Vert.
