05-11-2017 | #11 |
Re: Intermittent DNS
If you need a how to on bypassing the clutch switch I can post it when I get home from work tonight.
05-11-2017 | #12 | |
You are correct. I am on the road in Colorado right now and wasn't following you comments carefully enough. I suggest troubleshooting the starter circuit to identify a switch or wiring that is failing. I don't have any manuals with me so I will leave the explanation to others. Jim |
05-11-2017 | #13 |
Bypassing the switch is easy. Pull the hush panel and look up under the dash and look for the 10 gauge PURPLE WIRE plug,it should be towards left of the steering column. I have a jumper I made,if you were closer I'd loan it to you for some trouble shooting.
05-11-2017 | #14 | |
Sent from my XT1080 using ZR-1 Net Registry mobile app
1991 ZR-1 #520 Arctic White/Gray |
05-12-2017 | #15 |
Might not be much use but I posted my experience here :
http://www.zr1.net/forum/showthread.php?t=26832 Check out post #53 I posted a photo of the clutch switch on my 94. Just thought I would add that because I jumpered the wrong switch early and chased my tail for a while before I realized it. |
05-12-2017 | #16 | |
07-15-2017 | #17 |
So a couple weeks ago I had the DNS again. I replaced the battery and ran a bypass on the clutch safety switch and thought I had solved the problem. WRONG!!
This morning when I got in the car to go to a show I turned the key and no crank. I tried jumping it on both my pickup and a battery charger, waiting 5-10 minutes between each attempt. Then I ran a jumper between the purple wire and the VATS lockout relay. It will crank but will not fire. I have fuel pressure in the rails, plenty of voltage at the battery, but I dont know if the injectors are firing or if I have spark. When I crank it the tach needle comes off its stop but only shows 0. it is difficult alot of times to turn the key cylinder back so I can get my key out. Help!!! This is my dream car, but I've never had a car this unreliable.
07-16-2017 | #18 |
07-16-2017 | #19 |
Pull a spark plug wire then crank it with a plug checker or just a screwdriver to ground and see it you have spark. If no spark I'll bet it's a VATS issue.
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
07-16-2017 | #20 |
One other option is to put a secondary relay in for the starter,check out sticky thread in the ZR-1 second on the other site.
