Old 04-10-2017   #31
dredgeguy
dredgeguy's Avatar
Default Re: Fun in the Sun @WAZOO 4/8/17
Originally Posted by Roadster View Post
Thanking Jim for Rich's update on his possible vacuum leak(s), Al and Charlie for the updated reports on the work performed. I think it is important to share the results as mentioned earlier, so members can see what works and what doesn't. That way they will have a better understanding if they decide to take on a certain repair or maintenance.
BTW Charlie, we still need your report on how the engine feels with the replacement fuel pumps.....
My car feels good. I think the old original pumps were on their way out, now have 85,000 miles on my car. I wanted some insurance before MR5.
I did not want to push it hard until I get the small coolant leak resolved. Hope just another lose clamp and not the water pump. I will get it up on a lift to check this week.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 04-10-2017   #32
HAWAIIZR-1's Avatar
Originally Posted by dredgeguy View Post
Me too, my son is a LT in the Army (Fire Support Officer) currently deployed to Germany,Poland and the Baltics
I see. Congratulations and please thank your son for serving. Army Strong!!!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 04-10-2017   #33
Say hello from a former Army Red leg
ask him if he knows what
UP40FFE means
It was my personal license plate for 25 years.
Old 04-11-2017   #34
dredgeguy
dredgeguy's Avatar
UP40FFE means
Will do and thanks. He is out in the field so hopefully he will see the email and get back to me.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 04-11-2017   #35
Ahomans
Charlie, Where did you get your new fuel pumps? I am thinking of replacing the pumps in my ZR-1 as preventive maintenance. I believe they have 106,000 miles and 27 years of life.
Al
Ahomans is offline   Reply With Quote
Old 04-11-2017   #36
dredgeguy
dredgeguy's Avatar
I contacted Marc H and asked for his recommendation and he said he gets his from Rockauto. I ordered them online at rockauto.com, part number P240KC (2 needed) at $19.40 each plus $7.88 shipping so for less than $50 you get all what you need delivered. They were exact fit.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 04-11-2017   #37
Ahomans
Thanks, Charlie. I very much respect recommendations from Marc H. and have been satisfied with Rock Auto. Reasonable prices and quick delivery.
Old 04-11-2017   #38
Blownrunner
Originally Posted by QB93Z View Post
Yes you have to have the rear wheels off the ground (or lift) in order to allow the drive shaft to be rotated to get to all the u-joint strap bolts on the drive shaft at the differential. The C-Beam is not the issue for raising the rear end.
The drive shaft is a sliding spline connection at the transmission output shaft. Once the differential U-Joint is removed, the drive shaft can be pushed forward slightly and disengaged from the Differential then pulled aft to remove it from the transmission. Be ready for a small amount of oil when the driveshaft is removed from the transmission.
Note: On some cars the drive shaft can be removed with the C-beam in place. On some cars, you have to unbolt and move the C-Beam to get the drive shaft out.
The way to remove the C-Beam is as follows. Support the back of the engine with a jack and block of wood that is as wide as the rear of the oil pan. Make sure that the jack and wood block do not prevent access to the bell housing front shield bolts if you need to get to the clutch or flywheel. Remove the C-Beam bolts. If the bolts are under tension, raise or lower the back of the motor to relieve the strain. Using a hammer and wood block, tap the c-beam forward and away from the transmission. Then from the back tap the c-beam forward until it clears the front of the differential where the U-joint was. Next lower the rear of the engine until the c-beam is angled down and below the differential. Then slide the c-beam aft and off the transmission. Most cars require some hammering to accomplish this. I have done one ZR-1 where the c-beam could be removed with no hammering at all. The BFH is not necessary, it just completes the task with fewer strikes. Some times you just have to convince the part to go where you want it to go.
You could install the C-Beam plates without removing the C-Beam or the driveshaft, but you would not be able to inspect the surfaces. I don't think you could remove the C-beam without removing the drive shaft.
All of the above requires removing the Exhaust system.
To me, a 25 year old, 30K miles clutch on a ZR-1 is just getting broken in. The ZR-1 Clutch System is very robust in my opinion. I have removed many clutches from 80K or more miles cars that were in very good condition. If you don't have any drivability issues, I would leave it alone.
Installing headers is an all-day (8-hour) job for a team of workers. We have done a lot of header installs in WAZOO and it is not technically hard but there are a lot of bolts that require patience and ingenuity to remove and install.
Thanks so much for the responses, come to think of it I will just remove the clutch inspection plate and maybe do an inspection and be done with it. I also imagine that installing the new headers is a lot easier than removing the old.
Blownrunner is offline   Reply With Quote
Old 04-11-2017   #39
QB93Z
QB93Z's Avatar
The ZR-1 does not have a clutch inspection plate. The only way to see the clutch is to remove the transmission, bell housing and the clutch.
Old 04-11-2017   #40
nelson007
nelson007's Avatar
Does. FFE Mean fire for effect ?
Nelon
UP40FFE means
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
