Old 03-19-2017   #1
1LEZ
Default Z06/Z07 brakes fitment
I was wondering if anyone knows what has to be done to make the Z06/Z07 brakes work with Shelby Series One wheels. I've been told a spacer will work but I'm not into that solution. I have also been told that you can move the center of the wheel from the back of the barrel to the front. Does anyone have any experience with this application? What are you guys running for brakes with the Shelby wheel? Thanks in advance for your help.
1LEZ is offline   Reply With Quote
Old 03-19-2017   #2
G8nightman
G8nightman's Avatar
Default Re: Z06/Z07 brakes fitment
I was going to go down this road but went with GS calipers instead to avoid the hassle and guess work here is what the end result is
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 03-19-2017   #3
1LEZ
Nice. i currently have the same set up on my car. Thanks
Old 03-20-2017   #4
Hib Halverson
Are you talking about the carbon brakes used on C6 Z06es with the Z07 RPO?
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 03-20-2017   #5
1LEZ
yes, that is correct. I believe the rotor is slightly thicker on the Z07 RPO. Thanks
Old 03-20-2017   #6
Hib Halverson
The C6 and C7 carbon brakes use huge rotors, special pads and speciifc calipers. Adapting them to the C4 suspension may be a challenge.
The first thing you need is a ton of money because to buy those parts will run into some serious bucks, perhaps 10 large.
Secondly, you'll need at least 19" wheels to clear the calipers and then you need to determine the offset.
Third, you may need to change the master cylinder as the stock C4 master may not work with that system.
Fourth, you may have replumb some of the brake hydraulics'
I should add that, if you do decide to go "all-in" and put carbon brakes on your ZR1, you'll have more brakes than you ever thought possible.
On the other hand...if you suddenly develop a case of a really tight budget during tax season, consider my C4 brake upgrade for sale in the parts and cars for sale forum.
Hib Halverson
Technical Writer
Old 03-20-2017   #7
ssrszz4
I'm sure there are cheaper alternatives.
Sent from my XT1585 using ZR-1 Net Registry mobile app
ssrszz4 is offline   Reply With Quote
