Old 02-02-2017   #1
Roadster
Roadster's Avatar
Default Front inner fender skirt/cover removal
In the process of removing the upper front inner fender skirt/covers attached to the hood. I can turn the screws to loosen, but they are not coming undone. I imagine that with the age and weather along the way this may be a little difficult, as they almost feel like they are stripped. Will need new screws for sure.
Any recommendations for removal of these??? thx....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-02-2017   #2
Default Re: Front inner fender skirt/cover removal
Gone down that road. Do it every few years to keep things clean.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 02-02-2017   #3
Roadster
Roadster's Avatar
One day mine might look as good as yours.....
should have specified, I meant the upper covers attached to the hood. I don't want to proceed and make it worse than what it is!!!
just specified in post #1
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-02-2017   #4
billschroeder5842
billschroeder5842's Avatar
If strippef you will have to get a "fork" of some sort to gentely push between the fender and the screw. You can put pressure on fork pushing up while you unscrew.
Please take it easy or you will strip out the fiberglass pretty easily.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 02-02-2017   #5
Roadster
Roadster's Avatar
Sounds like a plan, I have one of those door panel removal tools which might work out....thanks for the tip...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-02-2017   #6
WVZR-1
I thought that maybe in '93 there was a change to a "rivet" that held the uppers to the hood. I can't say that I've any 1st hand but catalog information seems to confirm that.
What type of a head are you finding? Phillips or Torx? I thought earlier were maybe T-30 and M6.3X1.81.
Just curious!
Old 02-02-2017   #7
Roadster
Roadster's Avatar
Just curious!
My 94 has Torx screws...T15 seems to fit just fine, although some were a little elongated and have to use a T20.
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-02-2017   #8
Jagdpanzer
Jagdpanzer's Avatar
My 94 has rivits. I envy you guys with torx screws.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-02-2017   #9
Roadster
Roadster's Avatar
No need to envy anymore......what I thought were, looked like, and felt like torx screws, were not screws. They did turn out to be rivets. I have never see a head on a rivet like this before....needless to say they were a joy to remove.
And part of the rivets are now inside of the hood.....oh well!!! if only there was a trap door to remove them....I need a flexible pencil magnet....
WVZR-1, you were correct in your post, no need to be curious anymore...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-03-2017   #10
WVZR-1
I believe that at every location where you had a rivet there's a depression that you can modify the hood to use the M6.3X1.81 screw and the u-clip. I've a '95 hood here but it's buried bottom side to the wall and I doubt I'll have a chance to get at it early but maybe late in the day.I'll try to post back with a solution OR maybe someone has done it.
The screw you'll need is the same as the liners to the fascia and fender panels on earlier cars with the T-30 Torx or the ones used on the later years with I believe a hex. Here's an Ecklers link to what would have been on the earlier thru likely '92 hoods. Not hinting towards a buy but just showing you what I expect on earlier cars.
http://www.ecklerscorvette.com/corve...1984-1990.html
If you search eBay for 11514290 you can catch a glimpse of the nut that would be used.
http://www.ebay.com/sch/i.html?_from...14290&_sacat=0
