Old 01-15-2017   #1
Default The Worst Mouse Damage Ever
The Worst Mouse Damage Ever and the guy has not even looked under the Plenum. In this case I would be scared to look under the Plenum.
There are a lot of items the mice have chewed on that will prolly still function perfectly but look bad. I have never seen so many different items the mice have chewed on (and the Plenum has yet to be removed) as this case. Just a Warning.....it can get BAD
The Worst Mouse Damage TIPS
Old 01-15-2017   #2
ghlkal
ghlkal's Avatar
Default Re: The Worst Mouse Damage Ever
Dang ... I hate mice. I don't know why the like to chew up wires.
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 01-15-2017   #3
In this case they chewed sensors, Coolant hoses, windshield wiper hose. But....... another guy responded describing mice INSIDE the car which is even worse.
Old 01-15-2017   #4
BigJohn
BigJohn's Avatar
They use Mutton Tallow in the process of putting the insulation on the wires.
Old 01-16-2017   #5
lfalzarano
Use moth balls that come in packets and stuff them between the intake runners. Count the number that you deploy because you don't want to burn one you forgot to pull out before driving.
It also repels snakes if you deploy them near the door openings.
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR]
Old 01-16-2017   #6
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Learn something new every day.
I never knew that, but it certainly explains the attraction and gnawing.
As for the earlier post; If I were a mouse I would not screw with Boris either!
Maybe I could even learn to tolerate paw prints!
You go Boris!
(Actually, Boris appeared in a similar thread in Corvette Forum )
Marty
Old 01-17-2017   #7
Yikes
Old 01-17-2017   #8
I hope Boris had been de-clawed. I had a cat that used my freshly painted 1973 Challenger as a slide and I would have preferred to replace coolant hoses and electrical wires...
Old 01-17-2017   #9
nelson007
nelson007's Avatar
I store 6 Corvettes and I put Irish Spring soap under the seats, on the floor and on the engine block and never had any problem with mice. I do the same in my bus and that has been stored for almost 6 years.
Nelson
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
Old 01-17-2017   #10
Nelson
Hopefully placed by only good looking redheaded women in a full Irish brogue
