Old 01-13-2017   #1
TealZR1
Default PCV Valve Grommet
Appears to be a leak at my front PCV valve (very loose grommet) causing a high idle. I want to slip a small piece of vinyl tubing on the pcv nipples and than reinstall the grommet in hopes this will seal the grommet to the pcv. My question is what is the best way to remove the existing pvc valve. Any tricks to doing this? Very tight quarters. Thanks for your help in advance
TealZR1 is offline   Reply With Quote
Old 01-13-2017   #2
Default Re: PCV Valve Grommet
What do you mean, "front" PCV valve? There is a LH(driver side) & RH (passenger side)? Both of these items are available from www.jerrysgaskets.com under the PCV System category.
Old 01-13-2017   #3
PhillipsLT5
PhillipsLT5's Avatar
Replace all of your 25 year old dried up stuff from Jerry with silicone, these are just old cars that need help causing your idle issue
Old 01-13-2017   #4
Yes......I replace all PCV Connections just to get rid of the need for Hose Clamps
Jerry's Dual PCV Valve Connector
Jerry's Dual PCV Valve Connector Hose
Jerry's Dual PCV Valve Connector Grommet
New PCV Connections. Installation/Relocation of Plug Wires and New Spark Plugs
