Old 11-20-2016   #11
Default Re: Car Vibration - 50MPH+
Has the driveshaft ever been removed?
Old 11-20-2016   #12
TealZR1
Thanks to all for providing feedback - will take into a good driveline shop this week.
TealZR1 is offline   Reply With Quote
Old 11-20-2016   #13
aafc
aafc's Avatar
A friend of mine had a vibration problem at about 65-75 on his LT1. Tried the
all of the possible fixes. At last resort they checked the pinion nut (it was loose) replaced the crush sleeve, torque nut vibration gone.
1990 #2546 black/white
one of a few Auto eq (4L80E ) ZR-1's
Old 12-07-2016   #14
Tripler
Tripler's Avatar
Interesting . Our 1995 has begun to vibrate quite a bit after 60 mph in the steering wheel also and really heavy after 75mph . I have ordered new u-joints and drive shaft u-joints which will be replaced in the spring . I will also look into the shocks also as you have mentioned . Good ideas guys .
Thanks
Tripler is offline   Reply With Quote
