11-07-2016 | #11 |
Re: New cams
Well, I knew these cams wouldn't sit around long. The plan is:
Install the cams New lifters Time them Port the heads, matched to the IH's Remove the secondaries Install exhaust valve seals Replace the rod bearings Tune SS bolts Powder coat the cam covers Light weight pulleys Miss anything???? Last edited by efnfast; 11-08-2016 at 07:16 AM. Reason: forgot something |
11-07-2016 | #12 | |
Re: New cams
Injector Housing TB Coolant Blocking |
11-07-2016 | #13 | |
Re: New cams
11-07-2016 | #14 | |
Re: New cams
11-07-2016 | #15 |
Re: New cams
Well, this is the thread. Pictures will be the problem.
11-07-2016 | #16 |
Re: New cams
Tune should be
TUNE
11-18-2016 | #17 |
Re: New cams
Car heads to Dempseys (Oricle) next Friday. As long as the roads aren't salted.
11-21-2016 | #18 |
Re: New cams
Definitely interested to see the results. I was hovering over the "I'll take'm" button when you took them. I've already got all the other stuff done.
11-21-2016 | #19 |
Re: New cams
Oh. Lord...won't you buy me...a set of new cams
My friends all have got them....I MUST MAKE AMENDS! OH, LORD, won't you buy me...a set of new CAMS!! That's it!
11-21-2016 | #20 |
Re: New cams
Well, sorry for all the drama, but I put the project on hold again.
